5L3T-AA relay
Old Aug 24, 2022 | 10:41 PM
nasirsaeed's Avatar
nasirsaeed
1st Gear
5L3T-AA relay
Hi there!
I am new to the forum and have a question about 5L3T-AA relay taken out from Ford 500 car. There were three relays in the fuse box (in engine compartment). My A/C clutch was not working so i exchanged AC relay with the other one (next to AC relay of same number and shape, which was starter relay) and ended up messing with the car starter. If i get new relay can i get my car working. I messed up and now looking for advice, Also please tell whether these relays can be inserted in either direction? (like do i have to take care of the polarity?) As i dont remember now which direction was the original direction of the relay. when i check relay with multimeter its giving me 0 on two terminals (diagonally) and 133 ohms on two terminalys (diagonally). Thanks
Old Aug 25, 2022 | 06:17 AM
Franklin2's Avatar
Franklin2
What happens if you put the original relays back in their original locations? Most plugs and relays are dummy proof. It would be strange if you could put it in backwards.
Old May 10, 2024 | 10:04 AM
Wingerr's Avatar
Wingerr
1st Gear
Originally Posted by nasirsaeed
Hi there!
Just for reference, 1 and 2 is the coil terminals, and the 133 ohm reasons is good. 3 and 5 are the contact terminals, and 0 ohms is bad, indicating the contacts got welded together from overcurrent. It should be reading open circuit until you apply the 12V to the coil inputs.
You can plug it in either way and it'll work, but usually just matching orientation on all the letters on the label orientation with the other relays is how you'd want it, for OCD purposes.
Jd1a
Feb 22, 2023 02:18 PM
Shattered
Sep 21, 2012 11:04 AM
stroke-of-luck00
Oct 31, 2008 09:16 PM
mlkull
1983 - 2012 Ranger & B-Series
Jan 15, 2003 07:43 PM
