Pushrod questions...again
Old Aug 23, 2022 | 10:21 AM
KOT390's Avatar
KOT390
Just wondering if anyone has any advice on measuring for correct length pushrods on a newly built engine. Before first start up. I've read several posts and realize that I need to check clearance at the valve stem and rocker arm with the lifter collapsed. Is this safe to do on a new engine and lifters? Before rebuilding this time it was going to be a cam and lifters change. Well that cam fell apart on break-in so I'm obviously rebuilding it. When I put the cam in just this last time I was still suspect of the pushrods that came in it because some had bent and the valve train in general sounded bad. What I did that time was use comp cam pushrod length checker and measured 0 lash and then added .050" for preload. That was the size pushrods I got. Then I read recently about how to check the length as mentioned above, taking into consideration the geometry of the valve train. Now I don't know what to do. Sounds like the ones I have currently may be too short based on the way I measured for them. Thanks for any suggestions
Old Aug 26, 2022 | 08:29 PM
RKDxpress's Avatar
RKDxpress
Short answer 0 lash add .050 for preload.
Brent Lykins has nice a video on measuring pushrods on an FE.
Old Aug 27, 2022 | 07:37 AM
KOT390's Avatar
KOT390
Yeah thats kinda where I was at. I'm just taking precautions so that I make sure everything is correct when I get it going. Thanks for the video tip. Where can I find it?
highboyluke
Mar 19, 2017 09:05 PM
79fordrat
Jun 17, 2014 02:38 PM
atccracing
Feb 28, 2011 11:58 AM
ThunderTim
Feb 27, 2007 05:06 PM
allford86
Jul 10, 2005 08:02 PM
