Hi!
Old Aug 21, 2022 | 05:20 PM
ribsore's Avatar
ribsore
4th Gear
Hi!
Hello, I;m a new member to this site. I have a 1998 ford E350 Clubwagon with the v10 6.8L Triton engine. My reason for joining is because I keep getting obd codes P0300, P0302, and P0307. I've installed new Motorcraft spark plugs (sp479) and Motorcraft coil pacs on all 10 cylinders. It has a brand new catalytic converter and down stream o2 sensor. I replaced the fuel pump and fuel filter a year ago. It was recently hooked up to a smoke machine and there were no vacuum leaks. I tested the EGR valve with a vacuum gauge and it was good. It runs mostly smooth for a 24 year old vehicle (RV). There is a sporadic rattle/shaking periodically every now and then while driving. Any thoughts and suggestions would be greatly appreciated.
I'm thinking maybe fuel injectors? I've held a rubber tube to them and my ear and I can hear ticking. Maybe fuel filter needs changed again, but wouldn't that effect other cylinders?
Old Aug 21, 2022 | 05:58 PM
pbsdaddy's Avatar
pbsdaddy
Welcome to FTE. I see you have found the proper place to post your question(s). You might also try, Performance, Engines and Troubleshooting. And don't forget to join your state chapter, (Cali has two).
Old Aug 23, 2022 | 06:55 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I posted a reply over in your thread in "1968-Present E-Series Van/Cutaway/Chassis".
Welcome aboard!
Old Aug 31, 2022 | 09:17 PM
greenarcher's Avatar
greenarcher
This is the place for knowledge! Welcome
Laydbak1
New Member Introductions
Aug 12, 2018 11:41 AM
Aaron Aldrete
Jan 21, 2017 01:38 PM
papatango
Jan 9, 2015 11:49 AM
spikedog
Jan 2, 2007 11:07 AM
