Intake question
Old Aug 19, 2022 | 02:23 PM
Wyattsdadbill's Avatar
Wyattsdadbill
4th Gear
Intake question
Will a C8AE 9425 F8A25 intake fit my 1966 F-250 352 engine?
Old Aug 19, 2022 | 04:44 PM
85e150's Avatar
85e150
Looks like this?
C8AE-9425-F
Since your '66 already has the pentroof valve covers with PCV and oil fill, you should be able to bolt that right up.
It's a two person job in most cases as that manifold weighs 80 lbs or better.
Most of the comments on manifold installation say to use RTV on the china walls, not the cork gaskets.
With a stock engine and stock exhaust manifolds, a smallish 4bbl--500 to 600 cfm--would probably work best.
Old Aug 19, 2022 | 08:19 PM
Wyattsdadbill
4th Gear
Thank you so much. I have that carb. ready to go on it and yes they are a beast!
Have a great day!
Old Aug 21, 2022 | 03:11 PM
daveengelson's Avatar
daveengelson
Many years ago installed the same intake on my 64 352/390 Thunderbird engine w/. a mild 4bbl carb. and the 65 F100 runs great. Only significant change was that I went to a EI system and eliminated the cold winter morning hard starting issues.
Old Aug 22, 2022 | 09:47 AM
Wyattsdadbill
4th Gear
Thanks Dave. I appreciate the input!
Lax
Feb 28, 2017 11:56 AM
VitaminC
Mar 31, 2014 07:00 AM
Pipeplug
43
Sep 12, 2007 12:58 AM
toque
Apr 15, 2005 08:52 PM
aunchman
Oct 6, 2003 12:31 PM
