460 Misfiring
Old Aug 18, 2022 | 09:11 PM
Anthonyt3131's Avatar
Anthonyt3131
2nd Gear
460 Misfiring
Hello, this is my first post, here. Looking to get some advice on my 1997 F250 with a 460, 140k miles.
I had cracked the radiator and blew the head gasket in the mountains. Overheated back into town and let it sit until I saved up to take it to a shop to get the heads looked at. While it was at the shop, they replaced the cylinder heads with new iron heads (idk the specs), new exhaust manifold, distributor cap, plugs, and wires. I also replaced the radiator and the water pump myself.
Since I got it back from this shop, it felt like it was in limp mode (slow/jerky gearshifts, low power, etc.). The cat converter was stolen at the shops yard but the truck is manufactured in 96 so it is not OBD1, meaning there’s no missing O2 sensor. Fuel pressure was right where it needed to be when I tested it, but I replaced the regulator anyways. I also replaced the front-tank fuel pump a year ago. Also, I made sure to separate the plug wires so I don’t get any cross firing.
I am pretty lost on where to start any further diagnosis. Anybody have any guidance?
Old Aug 19, 2022 | 12:22 AM
OBS460's Avatar
OBS460
Does your truck have air injection? My truck is a 95 F350 (OBD1). In the red is where my only O2 sensor is located as well as the air injection tube for the cat. If they cut the cat and you have air injection that could be an issue?
Old Aug 19, 2022 | 07:55 AM
manicmechanic007's Avatar
manicmechanic007
1996 is OBD2 so it damn sure wants to see a rear HEGO (catalyst efficiency monitor)
You probably have a rash of codes
Try to put it back to stock with a cat and a rear HEGO and see what happens with the codes and the drivability concern
Good luck
puppyf250
18
Apr 9, 2020 07:56 PM
EllieMae94
Jul 29, 2017 07:59 PM
smurf91
1978 - 1996 Big Bronco
May 14, 2012 03:59 PM
Django92
Nov 20, 2010 05:10 PM
karljay
Jan 21, 2005 02:30 AM
