GDP Throttle Booster
Old Aug 15, 2022 | 10:23 PM
FullTimeRVr's Avatar
FullTimeRVr
1st Gear
I am installing a GDP Throttle Booster on a 2016 F350 Powerstroke. It seems pretty straight forward on the install since it's just plug and play with a connector foe the throttle pedal and a jumper that runs to a module. When installed it throws code P2138 - Throttle Position Sensor Switch D/E Correlation fault. Does anyone have any experience with installing one? I've rechecked the connections several times and I don't see any wire pin or connector faults. The code clears instantly when I remove the system back to factory.
Old Aug 16, 2022 | 07:19 AM
speakerfritz's Avatar
speakerfritz
you should contact the product manufactuer. a lot of them re-purpose their in-line circut iterupters to be used a cross numerous vehicle types....assuming their anolog device will be 100% compatiable with anolog and ditigal systems.
I do know that a lot of oflks use the banks pedal commander with no issues....
Old Aug 16, 2022 | 05:45 PM
Overkill2's Avatar
Overkill2
I'd also ask them if they have a fail safe built into that Throttle Booster meaning if the device fails, will it maintain the pedal... Many of these manufacturers don't have a bypass built into their throttle pedal systems. And if you're on a hill pulling a load, that would not be good.
But I would contact them to get this resolved as fritz said.
TXKR0317
May 18, 2018 10:48 AM
Jo7.3
Apr 28, 2018 09:42 AM
haledamage
Sep 21, 2016 07:18 PM
DieselCamper
Ford Truck Parts for Sale
Jun 9, 2016 09:46 AM
sweet55
2004 - 2008 F150
Aug 18, 2014 09:30 PM
