Driveshaft Angle adjustment feedback.
Old Aug 15, 2022 | 09:11 PM
Vasq1's Avatar
Vasq1
These are the current angles. Have a 1" spacer on the Carrier bearing bracket.
Let me know if what I've read is accurate. First driveshaft segment out of transfer case is thought as an extension of the motor/trans/TC and should be the same angle as the TC. In my case, it's down 3.2*.
Reducing the Carrier bearing spacer to get that first joint close or to 0*?
Is 1* ok between the TC and rear yoke? **Just found a 1* Leaf Spring shim on Ebay**
I will still take the entire driveshaft to get balanced for peace of mind.
Thanks in advance.
Old Aug 16, 2022 | 10:30 AM
knottyrope's Avatar
knottyrope
https://driveshaftshop.com/driveshaf...e-calibration/
is what i go by but i would like to learn more on the cause and effect of those angles
Old Aug 16, 2022 | 11:32 AM
Vasq1's Avatar
Vasq1
Yea, looks like I need to drop the rear pinion down 1" to match the transfer case yoke and raise the Carrier bearing to get it close to the 5.4*. And let the last two U Joints do all the angle work.
Old Aug 16, 2022 | 02:02 PM
knottyrope's Avatar
knottyrope
TC to carrier if zero angle will wear out ujoints so get it to almost 1
x2 and x3 need to be the same or you get vibes
good vid to watch
Old Aug 27, 2022 | 04:17 PM
Vasq1's Avatar
Vasq1
Here is the updated angles after reducing the spacer at the carrier bearing (since the way it is understood is the first section of the driveshaft out of the transfer case should be considered an extension of the TC) and getting the pinion angle to match the transfer case angle.
Im still off 0.5* on my rear pinion to match the TC... is that too much?
Are the two middle and rear U joint being off by 0.2* acceptable?
Old Aug 29, 2022 | 10:59 AM
knottyrope's Avatar
knottyrope
.2 might be ok as the axle will have its angle change under load some
thatsrealnice
Apr 4, 2022 06:55 PM
77460ford
Jan 28, 2012 11:05 AM
fordguy622
Aug 25, 2004 09:04 AM
brown 4x4
Mar 3, 2003 12:59 AM
