need help please going crazy
Old Aug 15, 2022 | 04:53 PM
Adam Chrisman's Avatar
Adam Chrisman
Question need help please going crazy
alright 2004 ford excursion issue is will not start when turn the key all it does is click. so i started by checking batts but they tested good so i moved on to the starter and just went ahead and replaced it with the 6.7 new. still the same thing so i went to all ground wires both of the batts wires were good and the ground strap at fire wall is good the only one i found broken was body to frame. now im at a loss.
please any help would be helpfull
Old Aug 15, 2022 | 05:07 PM
Tunafish389's Avatar
Tunafish389
Get a meter and see if you are getting voltage at the starter. Big wire will always have 12v, little red wire to solenoid will have 12v when key is turned to start.. If you have all that, check the voltage drop to the big wire to make sure you are not dropping below 10v when key is start position. If below 10v replace battery, if above the replace starter.
If you dont have the proper voltage then report back and we can go from there.
Old Aug 15, 2022 | 07:14 PM
JSPEX's Avatar
JSPEX
Is your shifter sloppy at all. I always start by holding up on the shift lever while turning the key to eliminate that first...
Old Aug 15, 2022 | 07:53 PM
Antonm's Avatar
Antonm
Try baring the engine over with a wrench on the front crankshaft bolt to make sure the engine isn't locked up for some reason.
Old Aug 17, 2022 | 08:42 AM
bwguardian's Avatar
bwguardian
Which power plant? I'm assuming you have a 6.0L engine given you installed the 6.7L starter. I know on the 7.3L engines the nose cone has to be swapped for the 6.7L starter to work...not sure if that's the same for the 6.0L if that's what you have...
Old Aug 18, 2022 | 05:06 AM
magicschoolbus's Avatar
magicschoolbus
I chased this the other day, my issue was when I wired my alternator to my starter solenoid I used a 3/8 electric ratchet and cracked the the solenoid housing, but this step by step video walked me through everything and I did have to replace quite a few old crusty wires but today no more issues.
StrokinIT2001
Mar 2, 2023 06:08 PM
65fordowner
Oct 22, 2014 12:16 AM
hollywoodswole
Feb 29, 2012 02:19 PM
str8racing
Mar 11, 2007 07:09 PM
ford429cu
Apr 18, 2001 09:40 PM
