Check My Boost
Old Aug 17, 2022 | 11:03 PM
carl2591's Avatar
carl2591
True dat... my back turbo bolt was barely finger tight.. today when it finalllllly got the exhaust collector hooked up turbo,, OOO MMMM Fricken GOODD,, that was a bear, I tighten the bolt to 20 ft lbs vs 18... and i will now check them in 6 months.. I did all this turbo with new viton oring in 2015 and the leaking just sorta started in like oct of 2021 as i recall.. now for the CNC HPOP line to come in..
one question... If i add oil to the pump on top will that help fill the new oil lines a bit?? When i check the level was quite low from the seeping of the crossover line i remove to do pedestal..
Originally Posted by Sous
There is a saying for these trucks and Harley motorcycles...
as i
Goes something like this...
If it ain't leaking oil, the pan is empty...
jojob1kz
Feb 22, 2022 09:15 AM
lakewood
13
Jan 17, 2020 04:14 PM
hytekredneck
May 6, 2008 08:16 PM
pmbmax
Sep 23, 2006 09:42 PM
bunnycop
Jul 24, 2004 02:04 AM
