Tilt wheel problems 79f150
Old Aug 14, 2022 | 10:47 PM
Bruce Baker's Avatar
Bruce Baker
4wd High
Hey guys, new guy here . Well to start I have a 79 f150 ranger Jade green with a 460 c6 . I've had it for 22 years and just found out that it has a tilt wheel, problem is the clips that hold the tilt bale are broken.Does anyone know where I can get them? Thanks
Old Aug 14, 2022 | 11:19 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
NO that part is NOT reproduced, if you can get it apart, take what is left to a machine shop and have them make you one.
Old Aug 15, 2022 | 12:34 AM
Bruce Baker
4wd High
Tilt wheel wire bale clips
Thanks for the info, just one on the bottom is broken everything else is fine, when you push the bale it lifts up and won't engage the release. Guess I'll have to hit the junkyard and try to find one unless someone on here has the clips that they can part with. Thanks again for the info
Old Aug 15, 2022 | 08:16 AM
77&79F250's Avatar
77&79F250
Pretty sure that is going to be a very hard to locate part, same for finding a JY with a tilt wheel that is in good shape. A lot of tilt wheels get uses as a grab handle and get worn out or loose/broken or people do not take the spring tension off (hold the steering wheel) before hitting the release lever.
Old Aug 15, 2022 | 05:42 PM
5851a's Avatar
5851a
You may find the part in any of the Ford cars with tilt before the wiper switch in column style. to be the same. I used some parts from an 80's truck in my 78 Bronco tilt and the adjustment tooth part broke from PO using wheel for grab handle.
EddieRiggs13
Nov 13, 2019 07:07 AM
ford303
Jul 31, 2012 03:57 AM
96sherm
40
Sep 26, 2008 08:08 AM
