Sponsored by: Auxito
M5OD Fluid Leak
Old Aug 13, 2022 | 11:49 AM
Aaronw12's Avatar
Aaronw12
M5OD Fluid Leak
I put a bearing and synchro kit in my M5OD about 2 years and 10,000 miles ago, the kit included metal shift rail plugs in place of the rubber ones. The tranny has now developed a fluid leak, it was fine up until this point. The drivers side of the trans is wetter than the passenger, the fluid appears to be running down the side. Any ideas for a likely source of the leak? It's difficult to see where it's coming from when you can't see the top of the transmission. Is there a plate on the floor of the 2003 F150 that can be removed to see the top of the trans? Thanks.
Old Aug 13, 2022 | 11:52 AM
RLXXI's Avatar
RLXXI
Should be able to remove the shift boot assembly to access the top plate.
Old Aug 13, 2022 | 02:29 PM
Aaronw12's Avatar
Aaronw12
The only thing I can access through the boot is the shift lever where it goes into the shifting forks. There was a bit of oily dirt under the lever cap so I removed the gasket and sealed the cap up with rtv. Hopefully that was the source of the leak.
Old Aug 14, 2022 | 08:28 AM
manicmechanic007's Avatar
manicmechanic007
Those rubber plugs have leaked since day one
Do not overfill the trans
Subzero68
24
Oct 22, 2016 03:21 PM
gravydude
Oct 2, 2008 02:37 PM
10bands
Aug 13, 2007 03:43 PM
ustolemycupcake
Mar 3, 2005 07:31 AM
ktplotts
1983 - 2012 Ranger & B-Series
Nov 30, 2004 11:19 PM
