Starting and Running Issue
Old Aug 12, 2022 | 09:38 AM
DJ17490's Avatar
DJ17490
1988 F250 460 5 Speed. Right so not too long ago I posted about an ignition issue here not having keys and all that. Still can't get the new ignition in, but the truck needs to move at some point, so starting it with a screw driver for now works. Problem is that right now it'll start, but the battery lights on, runs for about a minute before dying, almost as if I just turn it off, maybe half a second sputter before off. New battery, alternator was replaced last year and tested recently, solenoid replaced last year as well. Checked what ground wires I found and other than being a little dirty they seemed okay. Maybe I'm missing a major one hidden underneath or something, it seems like a ground issue but I'm not sure. When it does run it seems kinda slow at idle, and doesn't want to rev up much unless right after starting.
Old Aug 12, 2022 | 09:28 PM
Mo8414's Avatar
Mo8414
Might need a new distributor. The sensor inside it can go bad and make it not start.
Ddaybc
Oct 12, 2018 09:20 AM
farmboy87
20
Nov 1, 2015 08:36 PM
1977HB351m
22
May 12, 2015 10:55 PM
troyboy38
Feb 3, 2008 01:22 PM
lmadore
Sep 10, 2004 09:54 AM
