Brakes shutter when stopping
Old Aug 12, 2022 | 06:24 AM
highboy'74's Avatar
highboy'74
7th Gear
Hi, I just finished restoring my 74' High Boy and my brakes shutter when stopping, usually more when stopping from a higher speed / harder stop. Dana 60 in the rear (drums) and 44 hd closed knuckle (drums) in the front. All 4 brake drums, brake shoes and components are new. Any Ideas? Thank you in advance for your response.
Old Aug 12, 2022 | 07:58 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Are you 100% sure you have the brake shoes on correctly? Sometimes the smaller (shorter) and or bigger (longer) ones, called (Primary and Secondary shoes) gets put on incorrectly, meaning on the wrong side. As in the front and rear side of each wheel. I am pretty sure there is a difference, but it has been a while since I did the rear drums on a Dana 60. I just seem to remember that as a possibility. And it has been an even longer time since I messed with front drums brakes.
Old Aug 12, 2022 | 08:07 AM
highboy'74's Avatar
highboy'74
7th Gear
I thought that may be the issue initially so pulled the drums and took a look at the brake shoes and they are installed correctly. My thoughts are one of drums are out of round but they are new...
Old Aug 12, 2022 | 08:31 AM
77&79F250's Avatar
77&79F250
Well new parts should be good, but we all know that new parts are really just different parts that are supposed to be in better condition, but sometime are not. Did you NOT have this issue before the brake job? Or was the shutter the cause for the brake job to be done. Did you open up the brake system and replace the wheel cylinders? Proper brake bleed accomplished?
Condition of the master cylinder and power brake booster (do you have power brakes?). Condition of vacuum lines. I am sure you do not want to take the brake drum off again, but if you do, can you find a center fixed point to take some measurements from center to outer edge to confirm your out of round theory?
Old Aug 12, 2022 | 08:55 AM
highboy'74's Avatar
highboy'74
7th Gear
Thank you for your replies, Brakes worked 10 months ago when I began the frame off restoration. All new brakes line, hub, shoes & components. Old master cylinder & booster. I'm pulling the drums off right now to triple check brake shoe placement is correct. My understanding is the big shoe is on the back.
Old Aug 12, 2022 | 09:29 AM
77&79F250's Avatar
77&79F250
Well if I knew for sure I would tell ya, I am going to go check my OEM dealership maint manuals and see if it says anything in there on their installation. If I can find any thing that covers that specific part install, I will let you know. Only other item in the system not talked about, is the proportional valve, also called a combination valve.
Old Aug 12, 2022 | 11:55 AM
Mark8man's Avatar
Mark8man
Yep long shoe to the rear.
Can you tell if shuddering is coming from front or rear?
Can you feel anything in the steering wheel?
What happens if you gradually apply only the E-brake while moving?
Does it pull one way or the other when you brake?
Make sure you do not have any loose or incorrectly installed suspension components.
I'll usually have new brake drums checked for truenesss and being centered with hub. Just don't trust aftermarket especially if made in china.
Old Aug 12, 2022 | 12:02 PM
77&79F250's Avatar
77&79F250
Jason thanks for the "long shoe to the rear" input, and all the other questions. Spot on.
Old Aug 12, 2022 | 12:17 PM
highboy'74's Avatar
highboy'74
7th Gear
Thanks again for your replies. Feels like the shutting comes from the rear. I confirmed the shoes are on correct. With the truck raised and tires off I started the truck and put in gear to see if there is any wobble at the drums and sure enough the passenger side has a noticeable wobble. I adjusted the shoes till the drum drags and spun the drum. I could feel the brake drag and let go and drag again. Must be an out of round drum. That's my assumption at this point and I'll order another one.
I'll update the post after I order another drum. Thanks again!
Old Aug 12, 2022 | 01:11 PM
tbear853's Avatar
tbear853
That is correct. You could have an out of round drum. Have you any shops around with a brake lathe, might pay to take the drums for a quick check while they are off.
Last edited by tbear853; Aug 12, 2022 at 01:14 PM. Reason: I see already answered, my bad.
Old Aug 12, 2022 | 01:12 PM
77&79F250's Avatar
77&79F250
A couple of famous quotes from a FTE member to help you thru this.
“The bitterness of poor quality lingers long after the sweetness of low price is forgotten.”
"Quality of parts are like oats. There are new oats and used oats. New oats can be bought at feed stores, used oats can be found out on the road, after the horse passes by."
Better luck on the next drum you get.
Old Aug 12, 2022 | 01:15 PM
Yamhill Ranger's Avatar
Yamhill Ranger
I'd say it's likely to be an out of round drum, but....you might also check to make sure you don't have a bent axle/mounting flange. and also that the drum is concentric on the studs/hub (is there any slop there)?
Old Aug 12, 2022 | 07:49 PM
Greaser007's Avatar
Greaser007
Shuddering could also be hard linings.
About 20-some years back I began using standard linings because they seems more user-friendly and smooth feel to the pedal.
Hopefully your issues are just an out-of -round drum.
keep us posted on the results of the new drum.
Old Aug 12, 2022 | 10:46 PM
Vibguy11's Avatar
Vibguy11
This just happened to me. Same scenario, after the brake job it would jutter so bad that more and more rust would fall off the bottom. I narrowed it down by disconnecting the brake lines to each rear drum one at a time. Found out that one new drum from NAPA was not round. They replaced it and it is all smooth now.
Old Aug 14, 2022 | 12:42 PM
crazy96863's Avatar
crazy96863
I had a few similar experiences over years. Basically the drums or rotors feel ‘warped’ right out of the box. So I’d take them in to be turned and they smoothed right out. Now I do so before leaving the store.
I have even had friendly arguments with the guy in the brake shop telling me turning new rotors or drums isn’t necessary so I made a deal; if they needed turned, it was free otherwise I’d pay. I haven’t paid on any of those bets yet.
I don’t know why this occurs but I suspect the manufacturer machines before the parts fully cool down from being casted so it warps. I have found a statement on motorcraft/genuine ford rotor/drums that says in effect that they have been pre-machined and turning isn’t necessary to save the technician/customer time and money; this is the only brand I haven’t experienced this issue with but last I check this brand doesn’t make the brake parts for older applications.
rmalottwtes30
Mar 12, 2008 01:12 AM
ehrminator
Nov 7, 2006 01:22 AM
sharkdance
Mar 15, 2005 09:23 PM
41Clay
1947 and Older Ford Trucks
Nov 4, 2002 03:04 PM
