AC Vacuum diagram
Old Aug 10, 2022 | 09:41 PM
Vasq1's Avatar
Vasq1
AC Vacuum diagram
Any one got a 92-96 7.3 AC vacuum line diagram?
Attempted to put on that fancy CP Addict cold ac valve that uses the outside air motor vacuum but appears the hard white line is acting up once i touched it and no longer closing outside air. AC works great in Norm and can switch to defrost, floor,... but want to get my Max running right without outside air.
Although I did hear vacuum to the AC is pretty simple. Black hose from vacuum pump through the harness into the firewall (with the white hard hose from the recirc motor in the engine bay) into the dash. but from there, no idea what goes where.
Thanks in advance.
Old Aug 11, 2022 | 08:22 PM
Vasq1's Avatar
Vasq1
Well, never found the 92-96 7.3 AC vacuum diagram, but did read on some bronco forum that peeling back the wire bundle that the white vacuum tube enters from the AC re-circulation motor gets hard and breaks. Sure enough. When I exposed some of the white vacuum line in the loom, it looked much better. Just cut off the bad section of white hose with some good rubber vacuum hose and bam, no more outside air when on Max. Got the AC down to 55*, considering its 99* outside right now. wrapped the bundle with heat resistant electrical tape. Just need a T connector to connect the coolant line from the water pump to get that "max ac".
Old Aug 12, 2022 | 12:15 PM
73fan's Avatar
73fan
That's good info right there! Thanks for checking back with a repair.
Old Aug 15, 2022 | 12:00 PM
knottyrope's Avatar
knottyrope
take off that service door on the expansion chamber near ext manifold and do some cleaning. air flow will improve a lot if its never been cleaned
Old Aug 15, 2022 | 05:02 PM
timrothschild1's Avatar
timrothschild1
would you post a pic of the service door location
Old Aug 15, 2022 | 07:54 PM
Vasq1's Avatar
Vasq1
Likely hasnt been cleaned. Ill get to it this week. Good call.
Old Aug 16, 2022 | 02:18 PM
knottyrope's Avatar
knottyrope
Old Aug 17, 2022 | 09:11 AM
timrothschild1
Pic
Thankyou….
Old Aug 17, 2022 | 01:37 PM
knottyrope's Avatar
knottyrope
Thankyou….
welcome
also if you take the blower off, you can see the gunk that has been built up on it
My resistor was covered in mouse nest shorting it out
the drain was clogged up with nesting too
after i hosed it all out, it smells so much better in the cab and so much cooler with improved air flow.
insufishentfunds
Jun 19, 2018 02:31 PM
tperk100
Jul 24, 2011 12:08 PM
crazie0025
Oct 19, 2006 11:12 PM
Lance1601
Aerostar
Apr 14, 2006 02:41 PM
Jack01
Aug 30, 2005 09:02 PM
