What FE mod has impressed you?
Old Nov 17, 2003 | 01:51 PM
76_390FE's Avatar
76_390FE
Originally posted by CACWBY
how about the 428CJ windage tray?
I bought one and my engine builder said wasn't possible to use with H Beam Rods.
I'm still curious about MSD type ignition adders. Currently running Mallory unilite Distributor with Pertronix Ignitor II guts, Mallory Coil, Jacobs wires. I see that Mallory makes the HyFire, and I'm not sure if this is same as all the others (kind of seems like from reading Summit descriptions), has anyone used the Mallory HyFire?
I am running a Mallory Hyfire ignition in my 76 F-150 390. I think it is a lot like the MSD units, either brand is good.
Old Nov 18, 2003 | 04:05 PM
wyomingford's Avatar
wyomingford
Definately headers, The Ol' 390 just can't breath through those tiny manifolds.
Old Nov 19, 2003 | 06:04 PM
highboy 74's Avatar
highboy 74
Street Avenger 770 and performer intake
Old Nov 20, 2003 | 06:44 PM
scamardo's Avatar
scamardo
I absolutely love my FE. Had a 300 big 6 in and well, never going back!!
Has anyone looked at the Erson Roller Rocker Assembly as a mod? What benefit would you get from this mod?
Thanks,
Old Nov 20, 2003 | 06:48 PM
Andysutt's Avatar
Andysutt
I thought about getting that Erson Roller Rocker Assembly
you'd free up alot of horsepower due to friction
and its better I think
Old Nov 21, 2003 | 11:34 PM
biz4two's Avatar
biz4two
This is an excellent thread!
I have several mods, but I think my 390 has benefited the most from the following:
1. A Griffin Aluminum 1 1/4" tube radiator. Really keeps the 390 cool!
2. With that modification also included a new dual 27" flex-a-lite radiator fan setup. Works super "sweet". The variable speed control operates the fan from 60% - 100% (which is rated at 4600 cfm max). Slight fab work needed, but nothing very difficult. The really fun part about this mod...looking into the engine compartment and not seeing the old style fan shroud.
3. Edelbrock Performer Series: manifold, 600 cfm carb, time chain, cam, lifters, and water pump.
4. FlowMaster exhaust: Single 3" pipe with a 70 Series Big Block® II muffler. Less noise, but trademark sound!
5. Jacobs electronic ignition system. This works EXTREMELY well and I highly recommend it. Also Jacobs 8.5mm wires are used.
6. Optima yellow top deep cycle battery.
7. A K&N XStream® Air Flow Top filter combined with a 14" x 3" K&N air filter.
Thanks for this thread...hope it keeps growing!
Old Nov 22, 2003 | 12:26 AM
baddad457's Avatar
baddad457
Why all the filter area for a 600 cfm carb?
Old Nov 22, 2003 | 08:01 AM
dinosaurfan's Avatar
dinosaurfan
FE mods
The mod that made the biggest differance for the dollars spent was to change my ignition system. I had been running the original point system that the truck came with. Switching to a combination of jacob and Duraspark and Chrysler parts gives that' holy crap' experience that AK mentioned. It used to be that my truck would need the choke pulled out to start in cold weather. Then you idled in place for at least 5 minutes before you could even move. I had thought this was my own fault from my welding the exhaust crossover shut in the ex ports. After the swap to the Jacobs system, no choke to start, no need to idle to warm up. It goes like a scalded ape, even stone cold. The jacobs setup runs at about 8 amps ( points are 2 1/2 ) and the plugs are gaped at 080. I'm convinced that ignition power is the key, maybe more important that anything else you do. At least if you live anywhere it gets cold in the winter. I'm in Michigan, and we recorded -42 in deer camp last year. DF
Old Nov 22, 2003 | 08:52 AM
scamardo's Avatar
scamardo
Hey Dino, Can you post some info on the Jacobs system? I am interested.
Tim
Old Nov 22, 2003 | 09:04 AM
Ratsmoker's Avatar
Ratsmoker
I am too Cal. If you wouldn't mind could you make a separate post specifically for it so I can reference people back to it with an easy search?
Old Nov 23, 2003 | 02:48 PM
biz4two's Avatar
biz4two
Needing info on Jacobs? Here it is:
http://www.jacobselectronics.com/Default.htm
Best thing...It really works!
Old Nov 26, 2003 | 02:45 PM
Annihilator's Avatar
Annihilator
1. Dynomax jet-hot coated (inside and out) headers
2. Electronic ignition of just about any kind (pertronix is a good cheap way, even better with a Mallory or MSD box combined).
3. Using the Right Stuff Gasket Maker instead of the Cork/rubber type end seals on the intake manifold.
4. Adjustable rockerarms, Roller type ones would be even nicer but $$$.
5. 3.50 or 3.70 gears, 3.25 are ok and they now make custom ratios like 3.30, 3.40 and so on.
6. Aluminum valve covers, they don't leak like the stock stamped steel type and yes I know to not overtorque the stock or any type for that matter rule.
7. I am also contemplating the use of synthetic oil in almost everything like rear end, tranny, engine (after it is broken in well), any tips or advice on this one?
Old Dec 1, 2003 | 06:55 PM
  #28
fordman428's Avatar
fordman428
i think when i chnaged from a stock 2 barrell on my 390 to a 4 barrell it made a lot of difference with the exception of watching the gas gauge go down, i have headers on the way i have heard they help a lot maybe 30hp, next is an electronic ignition, thanks for all the tips guys keep them coming.
RideDiesel88
Mar 7, 2014 12:15 PM
Ronin 5729
6.4L Power Stroke Diesel
28
Dec 11, 2011 05:31 PM
eallanboggs
1997 - 2003 F150
Jan 23, 2010 11:29 PM
PHElectric
93
Sep 24, 2009 09:26 PM
ernesteugene
211
May 24, 2009 01:38 PM
