Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1980 LT900 decode
Old Aug 10, 2022 | 12:11 PM
Troy1988's Avatar
Troy1988
2nd Gear
1980 LT900 decode
Old Aug 10, 2022 | 04:21 PM
85e150's Avatar
85e150
Welcome to FTE! You get your own thread for a complete decode.
U90 = LT900 diesel, tandem rear axles
J = Detroit model 6-71 426 CID in-line six cylinder two stroke supercharged diesel engine.
V = Kentucky Truck Plant
HA7293 = 1980 numerical series
9A = white
204 = 204 inch wheelbase
U900 = LT900 diesel, 43,000 lbs GVWR. This conflicts with the listed GVWR of 50,000, but your truck was a special order which did include the heavier axles etc for the greater GVWR (see axle ratings below)
DZ8 = I do not have upholstery info, but this looks like a standard cab.
FL = Fuller model RT-09513 13 speed overdrive transmission
D8S
D8 = Rockwell (Timken) model SQHD rear axles, 38,000 lbs capacity, 4.88 ratio, with Hendrickson suspension
S = Rockwell (Timken) model FH-901 front axle, 16,000 lbs capacity, with power steering
212881
21 = Atlanta District Sales Office
2881 = Special Order Number
Old Aug 10, 2022 | 06:17 PM
Troy1988's Avatar
Troy1988
2nd Gear
Thanks for the help it’s greatly appreciated!
QUOTE=85e150;20512452]Welcome to FTE! You get your own thread for a complete decode.
9A = white
D8S
212881
2881 = Special Order Number[/QUOTE]
Hellboy_32
Large Truck
Jun 29, 2022 06:08 PM
MakeITwork
Large Truck
May 10, 2022 06:07 PM
ram384
Large Truck
Feb 15, 2020 07:32 AM
Brad Marcak
Large Truck
Dec 7, 2019 06:59 PM
fordtruckguy78
Large Truck
Oct 30, 2017 04:04 PM
