What wire is this?
Old Aug 6, 2022 | 09:46 PM
aroesti's Avatar
aroesti
What wire is this?
Hi everyone,
I have a 1989 F-150 Custom with the 5.0 engine. Found this in the engine bay:
The previous owner seems to have jumped this connector that's coming off the wire harness by the distributor. What wire is this, where does it properly connect to? I would like to restore this to proper working condition.
Thanks,
Andre
Old Aug 6, 2022 | 09:53 PM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by aroesti
Hi everyone,
Thanks,
Andre
Id say it may be the SPOUT connector which useually has a plastic jumper that inserts into it. the connector broke or was lost, my thinking. and the wire is cconnecting it. this allows the truck to control igniition timing proper;y once et with a light and that wire removed
Old Aug 7, 2022 | 12:06 AM
aroesti's Avatar
aroesti
Thank you so much for the quick response Aurora, that does indeed seem to be what it is.
I did some googling because I was curious what a shorted-by-default wire might be good for. It appears that this is actually in-line between distributor and PCM, allowing you ti open the circuit between PCM and distributor to stop the PCM interfering with timing. Learned something!
Old Aug 7, 2022 | 06:43 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Old Aug 7, 2022 | 07:48 AM
My4Fordtrucks's Avatar
My4Fordtrucks
LMR Mustang has them or you could get one from the junkyard. Maybe other places have them but I’m not sure.
Mdhanners
21
Dec 7, 2021 12:40 PM
motogotor
Sep 13, 2021 10:09 PM
amcauseitsearly
Jul 4, 2021 11:38 PM
Vamisk
Dec 9, 2020 12:47 AM
