Turbo
https://www.dieselorings.com/9-029-b...94-5-1997.html
Which raw material would you like to know? Our certified 321 Stainless tubing comes direct from RathGibson in Wisconsin, our 321 Stainless plate for flanges comes from Portland, Oregon, the 321 Stainless custom made bellows from California. All raw material is from American mills, then we mandrel bend, TIG weld, and assemble in-house. Then we use 100% made in USA custom printed boxes to package, and shrink wrap again, right here in-house. We are the only manufacturer of 321 Bellowed up-pipes, and the only ones that I am aware of that are made in the USA. All of this allows us to make a superior product that supports multiple industries.
Left passenger side for another day, as it is NOT currently leaking. Attached up pipe to baby’s butt first (as per Riff Raff’s instructions) and tightened manifold to up pipe last. Was a thin gap at pipe to manifold junction that I closed up by tightening bolts. Did the bellows stretch out a bit to accommodate that? Assuming so…
No real pull yet, but boost doesn’t seem any better and EGTs the same. No exhaust leak however.
I am going to hook on to the trailer in the next couple of days and give it a go. But if no change going to order a KC 300x Stage 1.
What should I be seeing for boost on a healthy stock system at 3,000? Will the 300x give more boost? If so, what kind of PSI should I expect at 3,000?
Thanks!
Chris
Manifolds leak, check there too. My driver side popped a leak so I have slightly elevated EGTs now.
Thanks!
Chris
