Hard Brake Line Install....Failure???
1. I changed out the 2 lines from the ABS module to the MC, not a problem. Threads fit and every thread I start by hand and never wrenched it until it was in good.
2. Changed the line from the ABS that joins to the rear pipe. Along this route there was 3 unions, none of these leaked or showed any signs of leakage after the install.
3.Everthing (thread) was finger started to ensure a proper fit.
4. The gas tank was shifted by me, dropping the front strap allowing enough room to remove old pipe, snake in new pipe and secure in the frame clips. (If you have the time, I probably would have removed the tank completely). As it was the truck was not driven in about 2 months.
5. Where the center axle brake hose snakes upward to a bracket (mounted to the frame rail) and to where the long pipe meets up presented me with 2 failures. I can't explain other than doing this on your back you don't get a good line of sight and "fittings and how they are lined up". I am confidant that my threading process was correct. If any any time it didn't go smoothly in, I stopped and started again. While bleeding the brakes manually, this area showed "droplets", when pressurized, it leaked. TEARS!!
6. Thinking this rear axle hose fitting was the issue , I changed out this 20 year old hose, reconnected and noticed every installers worst nightmare. When I finger tightened and wrenched it, there was still some brake juice coming out. Under pressure for the 2nd time, it leaked drops. MORE TEARS!
7. I also think removing the bed gets you an unobstructed view and wider open spaces to see, line up and move around. If you can get that bed off.
So, I did what every driveway mechanic does at this point, we filled it up with brake juice and limped it and my pride into the local mechanic.
I am awaiting the repair and hopefully it was a threading issues. I don't know if the flare fitting on the pipe failed. Something did as it leaked after 2 attempted fixes in the same area.
Has anyone ever gone through a repair only to have it go bust? And yeah, I don't even own a creeper so this was done with the truck on 2 jack stands, cardboard on the ground. I think ideally its best if the truck is in the air so your line of sight is not affected.......
I think changing out all of the hoses within the length of the job would be best too. Marrying old to newer fittings and threads might have caused something to go wrong here.
Anyone who has done this feel free to comment. I am willing to learn what could have gone wrong.
Here is the area that gave me ulcers. This pix is before I installed the new center axle brake hose that runs from the rear axle. It's "wet" in the pix. When pressurized, it was worse. Same result even when changing to a new center brake hose. Maybe the flare (bubble) fitting was compromised?
I would think that the flare has an issue. I am not familiar with the company that you purchased your brake lines from but when I make brake lines I am super-**** about making sure my cut is perfectly square and the ID & OD are completely burr free. Usually any imperfection will cause a leak.
Sorry to hear about your luck. Hopefully the shop can get you squared away quickly and easily.
— Dave
SS is harder than typical metal used for brake lines. You may have to tighten, loosen, and re-tighten the flare nuts to seat the SS lines. You may need to do the tighten, loosen, and retighten several times. (This is assuming you have the correct flare angle which you probably do). I bought a complete set of pre-bent and pre-flared brake lines for my 2002 pickup. I had to do this on my truck for a few of the fittings.
If your fittings all snugged up with finger tightening then I would guess the threads are all good. Take a moment to relax and then try the tighten, loosen, retighten on the leaky fittings...may take 20 cycles.
The copper-nickel "ez-bend" bulk brake line from Napa bends easy and flares easy. Usually one good snug with the wrench is all that kind of steel needs. And it seems to have excellent corrosion resistance. SS is tougher and needs more encouragement to prevent leaks.
If you have the old lines, take a look and see if they're single flare. I've seen "master mechanics" be plumb wrong more that once...they're only human. I've been wrong a time or two as well
Just a quick clarification on stainless steel....it's not hard, it's tough.
