Vibration chasing
Old Aug 10, 2022 | 09:43 PM
Hit Man X's Avatar
Hit Man X
We do. Usually when cooler out...
Old Aug 18, 2022 | 02:36 PM
knottyrope's Avatar
knottyrope
Originally Posted by BlueOvalLover
Wow, the timing of this thread is perfect.
01 F250, 7.3, Crew Cab, LB, 2wd
I took a trip from Dallas to Austin today. On the way back, I experienced the exact same vibration that Vasq1 described. It obviously wasn't coming from the front end. Steering wheel was not moving and no vibration from the front end. I've never felt a truck cab shake like that before. But it did feel like it was coming from the back of the truck.
After getting home, I found that my back left tire is badly worn on the outer edges, as if it had been driven under inflated. But the air pressure is fine. I also noticed that my LT Rear Tire is sitting 1 inch forward of the RT Rear Tire in the wheel opening. So, I'm starting to suspect a worn U Joint Strap like knottyrope found. But I don't see any movement or damage in that area.
I've run out of daylight, so I'll look closer tomorrow. Any other ideas?
you might have a stretched axle u bolt and bent top plate, similar happened to me. outer tire wearing and some cab shake at random times
Last night it got worse and i heard some new noises that i didnt like when hitting a bump. Felt like a shock fell off and the rear felt loose like low air. in tires.
Bjaspud!
Jun 26, 2021 01:03 PM
vulcrider
1983 - 2012 Ranger & B-Series
Aug 16, 2016 09:19 AM
Franko72
50
Feb 21, 2013 08:21 PM
whf
Jul 27, 2010 12:11 PM
jdrose
Jul 13, 2005 07:05 AM
