rear end rattle
Old Aug 1, 2022 | 01:28 PM
kylant's Avatar
kylant
rear end rattle
another issue
I have recently noticed a rattle coming from the rear. happens at all speeds over all terrain. i am unsure if it increases with speed, the wind noise obscures it.
it sounds like the noise a loose washer would make. it is not a snap or pop, not overly loud.
maybe brake caliper rattling on pins?
i am going to get under there and have a look at everything.
I have searched the forums, and don't find anything similar.
Has anybody had a similar noise and been able to correct it?
Old Aug 2, 2022 | 05:28 AM
Lou Braun's Avatar
Lou Braun
A coupler in your trailer hitch can produce a rattle. Recommend checking that first. Same thing if your spare tire is even slightly loose. In any case, your idea of crawling around under the truck is a good idea.
Old Aug 2, 2022 | 11:03 AM
B109's Avatar
B109
What Lou said. Maybe the receiver hitch reducer/pin?
Old Aug 2, 2022 | 01:35 PM
kylant's Avatar
kylant
no receiver or hitch/pin in.
it is not the calipers, addressed them yesterday.
it really sounds like a loose washer or c-clip rattling.
sounds more like a squeak/rattle. kind of like a dry bicycle chain squeak
Old Aug 2, 2022 | 03:18 PM
Kellem's Avatar
Kellem
My first thought would be exhaust/heatshield, maybe a hanger.
Report back once you find the culprit.
Old Aug 2, 2022 | 04:47 PM
2020STX250's Avatar
2020STX250
Check your spare tire too.
Old Aug 4, 2022 | 02:29 PM
kylant's Avatar
kylant
cannot find it. sounds like it may be coming from inside the brake, hub, dust shield area....🤷🏻‍♂️
Old Aug 4, 2022 | 03:23 PM
redford's Avatar
redford
FTE Leadership Emeritus
You may need tompull the rotor off and check the parking brakes.
motofreek77
Mar 8, 2017 12:20 PM
Jsim
Aug 6, 2015 11:09 AM
Wabbitseezin
May 13, 2011 11:10 PM
jschaible
1978 - 1996 Big Bronco
Jun 3, 2004 09:18 AM
