Sponsored by: Real Truck
code for EGR
Old Jul 30, 2022 | 09:16 AM
TruckoffFord's Avatar
TruckoffFord
code for EGR
Have 2003 F350 4x4 6.0, 416K
code P401 is regularly on
Replaced ERG, new connector
Can clear the code and within 60 miles code is back
Any suggestions
Thanks
Old Aug 2, 2022 | 06:17 PM
bmr4106's Avatar
bmr4106
6th Gear
You have to clean the EGR system
I have had the same problem with my ‘97 F250 with the 5.4L. There are quite a few YouTube videos on cleaning the Exhaust Gas Recirculation system. You may have to remove the intake manifold just under the throttle body. Buy yourself four or five spray cans of carburetor cleaner, long thin wire bristle brushes and even use pipe cleaners to manually scrub the small orifices. On the drivers side of the engine is a 3/4” to 1” tube connecting the exhaust manifold with the fresh air intake that can be a culprit.
Old Aug 3, 2022 | 12:50 AM
Evan_P's Avatar
Evan_P
The EGR system on the diesels is quiet different than the gas engines. There is no tune that feeds from an exhaust manifold to the cooler. The EGR cooler connects directly to the passenger side up pipe and is bolted to the bottom of the intake manifold which for the unskilled is no small task to remove on an early production 6.0 Powerstroke. To the OP, I assume when you say you replaced the EGR you mean the EGR valve? If so did you use an OEM EGR valve from ford when you replaced it? Aftermarket units are junk.
Old Aug 3, 2022 | 06:32 AM
bmr4106's Avatar
bmr4106
6th Gear
Apologies, I misread your post.
Apologies, I misread your post. You are right gas vs. diesel totally different animals.
Old Aug 3, 2022 | 01:53 PM
FiveOJester's Avatar
FiveOJester
P0401 is low EGR flow. The PCM calculates this by looking for a certain increase in the air temperature in the intake manifold (IAT2). That sensor gets pretty sooted up from the EGR flow. I recommend pulling it and cleaning and see if the problem goes away. It's on top of the intake manifold, just unplug and screw it out. See diagram below for location.
You could also have a restriction in the cooler or EGR pathway, but that isn't very common on the 6.0's. They usually just plug up the EGR valve which is easily removed and cleaned.
Super Guest
Jan 12, 2021 08:58 AM
tjschmidt1986
May 25, 2020 08:51 AM
olyellow
Feb 4, 2019 06:22 PM
modular2v
Feb 12, 2011 10:33 AM
