'87 F150 anti-lock woes
Old Sep 9, 1999 | 07:23 AM
mustang's Avatar
mustang
I have an '87 f150 with RABS. I used the chilton's troubleshooter to narrow it down to my computer is bad. Does anyone know where I may get a good used anti-lock computer or a good cheap new one or have specs so I can trouble shoot my circuit board and fix my old one.
thank you in advance.
Old Sep 9, 1999 | 09:37 AM
slik's Avatar
slik
Wow, I had my '91 Safari ABS computer go bad. New at a dealer was close to a $1,500 turn around. My local mechanic found a junkyard unit and got me back out the door for $500 and some change.
Before getting your new computer, did you try disconnecting the battery? This will reset the computer if it is still functioning.
Slik
Old Sep 9, 1999 | 09:54 AM
mustang's Avatar
mustang
Thanks for the reply. No I did not try disconnectiong the Battery to reset the computer. THat would make sense as I replaced the sensor on the rear diff and I dont think I have had the battery unhooked sense then. I will try it tonight! THank you very much.
Micheal
Old Sep 10, 1999 | 08:19 PM
slik's Avatar
slik
Hey Mustang,
Did you clear your problem or do you still have a bum ABS computer?
Slik
Old Sep 13, 1999 | 06:18 AM
mustang's Avatar
mustang
I tried resetting the computer by removing neg. battery cable for more than 30 sec. (more like 2 minutes) and hooked it back up. no change, still acts the same - brake and abs lights self test, brake light goes out and stays out but abs light comes back on after about 2 minutes and stays on.
another other ideas?
thank you for all the help so far.
mustang
Old Sep 13, 1999 | 06:25 AM
Mulletwagon's Avatar
Mulletwagon
Had the same problem on an 88 Bronco. Turned out to be the two-wire connector that runs from the negative battery post next to the radiator support was corroded internally. Those two light wires are the ground for the ABS and EEC computers. When I tried to disconnect the connector to inspect, it fell apart. After removing the plastic and soldering the wires, problem was gone. HTH
Old Sep 13, 1999 | 06:46 AM
mustang's Avatar
mustang
thank you very much!!! I looked at them when I had the battery cable off and wondered what they did. Now I know!!! I will check them when I get home tonight.
thanks a million.
micheal
Old Sep 14, 1999 | 06:45 AM
mustang's Avatar
mustang
Tried the ground connector last night. Looks like previous owner has replaced them. They are in very good shape. Still no RABS! anyone have more ideas or know where i can get a RABS brain box for not much money? Maybe somebody wrecked one that would still have the RABS box?
thanks for the help so far, guys!
Micheal
Old Oct 27, 1999 | 01:45 AM
Phil's Avatar
Phil
Still need a computer... I believe I have one if I didn't toss it in the trash when I last cleaned my garage....You can have it....got it at a yard for a few bucks a while back....Just to make sure it's the same one, it's a little gold box about 1-1/2 inches thick, about 5-6 inches wide and around 8 inches long, correct? It'll only cost ya the shipping....
Old Oct 27, 1999 | 08:46 AM
Phillip Guidry's Avatar
Phillip Guidry
have you heard of Standard Ignition Products,also known as "Blue Streak" to the older mechanics? They offer a complete line of reman. computers not limited to just engine computers!You can get ABS,body,trans. and security computers from them.If they don't have one anywhere in the USA ready for shipment,they will R&R (repair & return) your unit usually in about a weeks time!Also,brake product companies such as EIS,Raybestos & Wagner also offer ABS computers.
Phillip
Old Oct 27, 1999 | 09:55 AM
mustang's Avatar
mustang
Thank you very much for the info. I use Standard Ignition stuff on my ag equipment yet. didn't know they did the reman stuff though. Thank you.
If I need to I will check into that.
Thanks for the valubale info!
mustang
Old Oct 28, 1999 | 08:16 AM
Phillip Guidry
purecty
42
Jul 5, 2015 01:32 AM
the_real_zekenator
Oct 30, 2013 12:37 PM
Hotairjunkie
Jun 26, 2013 08:40 AM
tinker
Mar 5, 2001 07:43 AM
trvaughn
Sep 23, 2000 01:42 PM
