DUI (HEI) distributor problem and fix
Old Jul 28, 2022 | 11:35 AM
jniolon's Avatar
jniolon
old and in the way
`Recently had a problem with my DUI distributor (Performance Distributors)...while cruising the truck would stumble and then die... get it to the side of the road and try to crank it..it would hit but never catch till finally it would start but run rough and I couldn't get the rpms up to drive... Volt meter also dropped below 12 volts when this happened... Once I could get the rpms up to 1500 or so and the alternator kicked in it would clear up and run fine... Happened two or three times... Engine temp never got above 200 and when cranking starter would spin engine quickly so I ruled out the battery (later tests showed battery fine under load)
I called Performance Distributors and a very nice lady offered no help other than check my connections and make sure my feed wire was adequate size.. So I went to my local mechanic (YOUTUBE) and found this video which described my problem perfectly
Pulled the cap and found exactly what he described and repaired... Todays test proved it... Truck ran great and seems to perform a little better, although that could be imagination
thought it might help someone else
john
Old Jul 28, 2022 | 03:20 PM
tip49's Avatar
tip49
Happy ending
Good job John. At first I thought it was the yellow paint but realized his truck is Orange not Yellow.
Get out and put some miles on.
Old Jul 28, 2022 | 03:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Hard to believe DUI hasn't incorporated the fix into production. For that matter it's hard to believe their engineers didn't realize the problem before shipping them out.
Old Jul 28, 2022 | 09:10 PM
jniolon's Avatar
jniolon
old and in the way
I agree completely, Ross... if it's on Youtube it must be a common problem. I sent an email to DUI folks linking the video...maybe they will pay attention
j
Old Jul 29, 2022 | 11:08 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Thanks for doing the leg work John. I'm sure this will be helpful to many on here.
Old Jul 30, 2022 | 08:05 AM
Steve Bennett's Avatar
Steve Bennett
Very interesting John. I wonder if DUI changed their process of manufacturing or I am just lucky. My DUI has been in my truck for about 8 years and 15,000 miles 351 W engine. Maybe because my DUI is Ford Blue?? LOL! Good Luck and Happy cruising, Steve
Old Jul 30, 2022 | 08:35 AM
jniolon's Avatar
jniolon
old and in the way
Hey Steve...good to hear from you... don't know about their process changing... I saw several videos showing the powder coating on the frame of the coil... It's really a design flaw and it should have been caught by now. I talked to 'someone' at Performance Distributors and she didn't seem to be the tech person as she had to go ask someone... their only solution was to check connections, grounds and wire size.. She never said "Check OUR grounds". I expected better tech support on a 400 buck distributor too. I followed Davis way back in the 70's when I was building another truck and he was addressing the Ford electronic ignition and recommending certain grommet colors over others...I talked to him personally several times and he knew his stuff... Still got one of his books around here somewhere...
You going to CTC this year ?? We aren't going...Even with gas prices down a little it's still an expensive trip for us. I used to get rooms comped at the casinos but since Covid stopped all our travels I don't get the offers any longer and everything is was more than it used to be. Plus the crowds and traffic have only gotten worse... Even the back roads are a parking lot nowadays. I sure miss it in the old days.
j
Old Jul 30, 2022 | 10:12 AM
Steve Bennett
We pre-registered last year for 2023 CTC. Have my confirmation card already in the '54. Been spending most of my time lately finishing up our 1955 Chevrolet. Just got it back from the interior shop. It looks awesome! It's a crew cab (4 door) which most people frown on but it was just what we were looking for. Grandboys always wanted to go to CTC with us, but no way in a pick-up. The '55 is not registered but we'll probably go down at least one day in it. We travel back and forth every day but we are only 110 miles from cruse central. These things are meant to cruise! Hope to cross paths with you again at some point. Now get out there and drive that beautiful truck!! Steve
jniolon
Jul 4, 2022 09:49 AM
olthunter
Mar 15, 2008 12:02 PM
wontquiteturn
Oct 19, 2006 05:03 PM
TripleCorpseHammerblow
1978 - 1996 Big Bronco
Oct 19, 2003 08:08 AM
steve83
Dec 19, 2002 04:12 PM
