Oil Pan leaks
Old Jul 27, 2022 | 10:43 AM
SwampRattFord's Avatar
SwampRattFord
Oil Pan leaks
I get oil seeping/leaking around the bolts on the oil pan. Two questions.
1. What it the torque specs on the oil pan bolts?
2. Is there a thread sealer I can use in the oil pan bolts?
Thanks in advance!
Old Jul 27, 2022 | 01:20 PM
'65Ford's Avatar
'65Ford
Can't remember the torque spec...somewhere around 15 - 20 inch lbs is my guess.
I doubt sealant on the bolts will stop any leaks. I believe they are blind holes so oil does not go through them. The pan can be removed and replaced on FE engines in 2wd trucks by raising the engine off of its perches and dropping the oil pump. It is a pain in the butt.
Old Jul 31, 2022 | 02:23 AM
624WD's Avatar
624WD
If you need a new pan - send me a private message. I have a new in the box pan I’m not using.
wicat3
Apr 19, 2012 09:54 PM
Z-MAN
Mar 6, 2012 10:50 AM
JGreen236
Dec 10, 2009 10:53 AM
93truck
Escape & Escape Hybrid
Dec 12, 2006 08:14 PM
morrigj83
20
Mar 4, 2004 04:35 AM
