oil pan replacment help.needed!
Old Apr 19, 2012 | 07:34 PM
wicat3's Avatar
wicat3
Hey guys i got a few quick questions. First I have a 92 150 5.0l 4x4. I'm attempting to replace my oil pan but I'm having trouble breaking some of the bolts free! Mainly the small 10mm bolts. Any advice on getting them out?
Second thing is it looks like there is a metal guide if you will that sits in the lip of the pan? Goes between the bolts and the pan its self. They look rotted away and I was wondering if I needed them and if so can I order a new set?
Old Apr 19, 2012 | 08:24 PM
dmanlyr's Avatar
dmanlyr
Those metal rails are there to reinforce the lip of the oil pan, to keep it from warping / leaking when the retaining bolts are installed / tightened, dare I say torqued to specs? Naw, I always just tighten them down!
But yes, they are needed and can be ordered with the new pan & gasket. I would recommend you get the premium silicone oil pan gasket with the anti-crush inserts. It will really help with weepage in the long term.
As to the bolts, perhaps a bit of PB blaster and some soak time?
David
Old Apr 19, 2012 | 08:29 PM
wicat3's Avatar
wicat3
Can u get the rails seperatly? I have a new pan and no new rails. What would I call them?
Old Apr 19, 2012 | 09:54 PM
dmanlyr's Avatar
dmanlyr
They are the reinforcement rails, that is all I have called them. yes they are available seperatly, but most of the time the new oil pans come with them (Marine engines are what I am 100% familiar with in this respect, perhaps the automotive oil pans are sold differently or with a different parts make up in the box)
You should be able to source these at a junkyard as well. New would be nice however as it sounds like you are dealing with a rust prone area and the J/Y ones might be as bad.
D~
Tyler_m
Jun 29, 2018 06:35 AM
JGreen236
Dec 10, 2009 10:53 AM
Ford Breakdown
Apr 6, 2009 04:40 PM
n9lhm
Aug 27, 2005 08:59 PM
morrigj83
20
Mar 4, 2004 04:35 AM
