Sponsored by: Real Truck
Help with P0305 code
Old Jul 27, 2022 | 03:25 AM
1999HDSD's Avatar
1999HDSD
6th Gear
Hello all. My 99 F250 is throwing a cylinder 5 misfire code. Weird thing is, it never gave me a check engine warning. Is that normal. It felt sluggish and idle seemed a bit rough so I put my code reader on it. It does not have the original coil packs on it. My question is what is the most likely culprit? My plan is to replace the coil pack and spark plug regardless but what are the chances it is an injector or something potentially more serious. Thanks.
Old Jul 27, 2022 | 06:36 AM
projectSHO89's Avatar
projectSHO89
It helps if you identify your engine...
If it's an OBD1 calibration, yes.
Probably. You could always swap with an easily accessible cylinder to see if the misfire moves or stays with the original cylinder.
Old Aug 28, 2022 | 08:45 AM
Parkerklein3's Avatar
Parkerklein3
3rd Gear
I actually just had the same problem with my 08, ended up just being a spark plug. Best of luck to you!
sniperscoutwill
Modular V8 (4.6L, 5.4L)
Mar 1, 2017 01:27 AM
chrischaugen
1997 - 2003 F150
Feb 13, 2014 01:07 PM
greenterror
Jan 21, 2008 02:01 PM
yuenglag
1997 - 2003 F150
Oct 18, 2005 10:23 AM
jamyboy
Jan 6, 2003 09:33 AM
