'99 F150 missfire code
Old Feb 24, 2017 | 05:15 PM
sniperscoutwill's Avatar
sniperscoutwill
Have a friend with a '99 F150 4.6 that is throwing a code. She had it scanned, was told "missfire cylinder 1". Mechanic replaced the spark plug and cleared the code. CEL came on again the next day, had it scanned again, same thing. Could it be a bad coil? Ideas? Thanks for the help!
Old Feb 24, 2017 | 05:36 PM
z31freakify's Avatar
z31freakify
Swap that coil to another cylinder and see if it follows. Go to eBay and get a cheap set you'd be surprise they are actually alright, I've used them on the fleet, and on my wife's Excursion and they last.
Old Mar 1, 2017 | 01:27 AM
R&T Babich's Avatar
R&T Babich
X2 on moving the COP to another cylinder to see if the problem follows.
You can get a basic code reader at Amazon for $12.95 - Oxgord CAN OBD II Scanner Tool.
Depending on how far away the mechanic is the savings in gas might pay for the reader after a couple of trips.
The spark plug probably wasn't bad since the code came back.
My guess would be the boot has deteriorated to the point it is arcing thru.
The coil may be fine, they last a lot longer than the boots.
How many miles since the boots were last changed?
NAPA Belden 702418 boots are around $6/ea and work well.
Denso 671-0001 boots are $30 for 10 on ebay which would give you 2 spares.
Denso 673-6000 COPs are $26.50/ea if you need the coil and boot.
jfp3205
2004 - 2008 F150
Oct 10, 2013 07:36 AM
zman025
32
Aug 28, 2012 08:28 PM
greenterror
Jan 21, 2008 02:01 PM
RobbyMartin
Modular V8 (4.6L, 5.4L)
Nov 30, 2005 07:17 PM
jamyboy
Jan 6, 2003 09:33 AM
