1996 Ford F250 - Brake Warning Light
The brake warning light comes on and stays on after the truck has started. It stays on for a couple of minutes and then goes out. Then when I either put the truck in gear (Automatic) and use the brakes the light comes on and stays on for a couple of minutes then goes out. The fluid levels are fine. I just had new brakes put on a couple of months ago, but this problem didn't start until a couple of weeks ago. Any ideas.
The ABS light does not come on. I have trailer brakes hooked to the cold side of the brake switch.
