Coolant odor when AC running
Old Jul 23, 2022 | 05:52 AM
arno327's Avatar
arno327
6th Gear
Question Coolant odor when AC running
1990 F150 Lariat XLT, 5.0L V8, 4WD, 5-speed: when i turn on AC i immediately get odor of what i take to be coolant; truck is not overheating, engine always runs cool, no coolant loss, AC works fine; heater hasn't worked in years (in Hawai'i, so kinda don't care), no wetness on passenger side floor . This just started a few days ago, but is so obviously different - i've had the truck for 32 years, so know all the sounds and smells.
Any ideas what's going on greatly appreciated. And, PS - this truck is the single best tool i've ever owned. Aloha!
Old Jul 23, 2022 | 08:29 AM
jas88's Avatar
jas88
You state your heater doesn't work - are the heater hoses still hooked up to the heater core?
Old Jul 23, 2022 | 01:44 PM
arno327's Avatar
arno327
6th Gear
they should be - i haven't disconnected them.
Old Jul 23, 2022 | 02:04 PM
SFaulken's Avatar
SFaulken
You've probably got a heater core weep. There's literally *zero* way for the air path or refrigerant circuit to mix with engine coolant. Other than something leaking in the heater core, if you're getting a coolant smell with the A/C on.
Old Jul 23, 2022 | 03:18 PM
TexasGuy001's Avatar
TexasGuy001
Old Jul 23, 2022 | 09:33 PM
cooksmtn's Avatar
cooksmtn
I had a similar situation with my '91 7.3, on a road trip. Made it home and immediately determined it must be the heater core, so ordered a replacement (not as good quality as original). Old core showed no signs of leakage, so I eventually pressure tested it and it was good. My leak ended up being one of the hoses at the connection nipple, but the leak ended up on the inside of the firewall, creating that unmistakable stench.
So check (and maybe replace) your hoses before replacing a core. Coulda saved myself time and money if I had been more diligent in my inspection.
Old Jul 24, 2022 | 01:33 AM
arno327's Avatar
arno327
6th Gear
many thanks to all who have so thoughtfully & rapidly contributed their thoughts. Gonna drop the glove box and investigate that little corner for a start,
psd96
Aug 6, 2012 06:17 AM
droffan
May 3, 2012 05:04 PM
flysniper
Jun 6, 2009 04:43 AM
Wr3ckin_Cr3w
2004 - 2008 F150
Sep 21, 2007 08:20 AM
HiTech
1997 - 2003 F150
Jun 18, 2002 06:21 PM
