What do I need to fix?
Old Jul 21, 2022 | 05:54 PM
sf250's Avatar
sf250
Trailering
I have a 2000 f250 with the 5.4 inside of it. It’s been sitting for a year and I decided that I wanted to try and start it. But when I put a battery in it it didn’t start and we sprayed some either inside of it and it ran for a minute till I Took my foot off the gas and it died. So I put a new fuel pump in and a new battery and when I started it it started to run and got up to 600 rpm and then died and now when I turn it over it might bump up to 300 rpm but then die down and just turn over. So I wanted to know if anyone had this same problem?
Old Jul 21, 2022 | 06:16 PM
lv2race's Avatar
lv2race
New gas or old gas? Replace the fuel filter.
Check for codes.
Remove the IAC and thoroughly clean.
Old Jul 21, 2022 | 06:19 PM
sf250's Avatar
sf250
Trailering
Check for codes.
it’s brand new fuel I just got at the gas station and put in a 5 gallon jerry can
fuel filter was just replace before it was parked
is the iac in the intake because who ever parked it last I guess took the air filter for their truck
Old Jul 21, 2022 | 11:10 PM
lv2race's Avatar
lv2race
On my 2000 Expedition 5.4, it's on the back of the intake like the attached video. I've seen them in other locations too. If your somewhat mechanically inclined, you'll have no problem removing, cleaning, and reinstalling. Before buying a new one, give it a good cleaning with intake and throttle body cleaner.
Remove the negative battery cable and carefully remove the IAC saving the gasket. Spray intake and throttle body cleaner in the holes and let it soak, drain and soak again, then install. Many videos are available online. Good luck!
Only bummer is yours may be like this one. A little more labor intensive, but clean it just the same. Clean the intake and clean the throttle body too. Just don't use any silicone for a gasket seal.
Old Jul 21, 2022 | 11:20 PM
sf250's Avatar
sf250
Trailering
https://www.youtube.com/watch?v=abX5TlmT3Oo
https://www.youtube.com/watch?v=rNQGEGvophg
ok I think I found it buts it’s too dark out so I’ll try this tomorrow
and see how it goes
Old Jul 27, 2022 | 06:38 PM
sf250's Avatar
sf250
Trailering
sorry it’s been so long I had to go out of town and I couldn’t get around to doing it but I came back and tried starting it for a “what the hell maybe I’ll be lucky” reason and it does this so do you think it’s still the iac? It happened so fast then died and I didn’t touch the gas at all
Old Jul 27, 2022 | 06:41 PM
sf250's Avatar
sf250
Trailering
This is the video
https://youtube.com/shorts/tE068EuEd7k?feature=share
Old Jul 28, 2022 | 12:35 PM
lv2race's Avatar
lv2race
After sitting for a year, how long were you able to get it to run? Maybe there is still old fuel in the line? Check the hoses for breaks or cracks including the PCV hose. Spray throttle body cleaner into the intake while you have someone try start it. Definitely check for codes. Even with a new fuel pump and filter, check the fuel pressure. Looking at the removal process, I would replace instead of cleaning the IAC. Get Hitachi brand as it's OE.
https://www.rockauto.com/en/moreinfo...BKJLetzb8jnXa3
Old Aug 6, 2022 | 02:49 PM
sf250's Avatar
sf250
Trailering
sorry it’s been so long but I’ve been doing some stuff around the house but anyways I managed to get the truck running by just bypassing the inertia switch which I thought was fine because it clicked in and everything? But oh well I have a new one on the way and that Will replace the jumper wire I have in there now but thanks for the advice I’ll still probably take out the iac because it does seem to idle a little high
Old Aug 7, 2022 | 04:31 AM
JWA's Avatar
JWA
Thanks for updating your thread---might be helpful to others in the future!
sf250
Jul 22, 2022 01:43 PM
Chrisjstrn
2004 - 2008 F150
Dec 12, 2021 10:44 AM
Dilligas
15
Feb 4, 2008 07:41 AM
49er_rs
1997 - 2003 F150
Oct 22, 2007 06:22 PM
TBloggins
1997 - 2003 F150
Aug 14, 2006 05:06 PM
