Does rear BLIS module need calibration?
Old Jul 19, 2022 | 07:36 PM
lcseds's Avatar
lcseds
I have a 2020 F350. I backed into something and broke the rear tail lamp. They are not sold without the BLIS radar module (thanks Ford), so it's an $800 assembly. One body shop said it would have to be calibrated. $400 for that. So does a BLIS radar replacement need calibration? Two other body shops said noting about calibration. What say you, auto body and mechanic specialists?
Old Jul 19, 2022 | 08:13 PM
RapidRed7.3's Avatar
RapidRed7.3
I am neither an auto body or mechanic specialist, but I have swapped tail lights in my SD. Chances are if you still have your broken tail light and you did not cream the light you can swap your blis module from the broken light into the new light and completely avoid calibrating the new module. The module is just held in place with 3 bolts and 2 screws.
If you have to use the new module because your old module is ruined, yes, you'll have to have the module calibrated.
Old Jul 20, 2022 | 05:45 PM
lcseds's Avatar
lcseds
Thank you. Module is okay, just punched a hole in the top of the lens. Guess 2 of 3 auto body placed knew they could do that. Appreciate the info.
Old Jul 20, 2022 | 07:41 PM
sleddinfool's Avatar
sleddinfool
$400.00 to calibrate--or programming is what its called. I need to up my labor.. My shop gets one hour or $140.00 to do that..
Old Jul 20, 2022 | 07:48 PM
lcseds's Avatar
lcseds
Yeah. That shop also gets $150 diagnostic pre scan and $150 diagnostic post scan. So $700 in scans and calibration. Harsh for an out of pocket repair. Figured this shop was Hollywood.
Old Sep 11, 2024 | 10:57 AM
orbsah's Avatar
orbsah
Picking up on an old thread . . . . . I need to do some very minor body repair just under the tail light. There's no damage at all to the tail light/BLIS but would be much easier if I removed it temporarily while I'm doing the work. One body shop that I talked to said anytime that tail light assy is removed the BLIS needs to be recalibrated. Is that really the case? If I unplug the tail light connector, then re-plug it back in, will the truck know that I messed with it and give me some fault indicator? Thanks!
Old Sep 11, 2024 | 11:08 AM
RapidRed7.3
That body shop is misinformed. No issue unplugging taillight.
Old Sep 11, 2024 | 01:09 PM
Black Buzzard's Avatar
Black Buzzard
I replaced my rear tail light by reusing the old blis from the original cracked tail light. No problems or recalibration needed.
Old Sep 13, 2024 | 08:48 AM
orbsah's Avatar
orbsah
Thanks - I appreciate the feedback!
Dale Massey
Aftermarket Products
Jan 31, 2019 10:14 PM
04F-250mark
Mar 7, 2012 11:32 AM
Propr801
Dec 2, 2009 09:07 PM
300i6
Jun 21, 2007 10:46 AM
steve_
Bronco II
Mar 24, 2002 10:15 PM
