Broken Bolt... Help!
Old Jul 19, 2022 | 09:54 AM
tristahx's Avatar
tristahx
2nd Gear
We own a 94.5 F250 7.3L Turbo Diesel, the rads thermostat was stuck so my boyfriend was removing it for the time being. He just came inside and informed me he broke a bolt off in the hole the thermostat goes into. There is hey limited room in that area and we fully have access to a welder. What can we do to get that bolt out?
Old Jul 19, 2022 | 10:19 AM
z31freakify's Avatar
z31freakify
Remove the water pump, might as well replace it if unknown history, add a billet thermostat housing and add anti-seize to the new bolts.
Old Jul 19, 2022 | 11:38 AM
helifixer's Avatar
helifixer
As z31 said just replace the water pump, do not run it without a thermostat it is a dual function thermostat and needs to be there. Also there is a short and long stem options.
me personally I will only install a motorcraft thermostat.
Old Jul 19, 2022 | 02:45 PM
97-psd's Avatar
97-psd
As mentioned, replace the water pump and he done. Do not run it without a thermostat.
annaleigh
43
Feb 5, 2020 07:33 PM
Bowie
Jul 15, 2015 03:37 PM
weatherbee00
21
Feb 15, 2012 08:35 AM
Mr.Ford 351W
General Automotive Discussion
Apr 29, 2007 06:47 PM
Beast12
Mar 24, 2005 01:34 PM
