We purchased a 1997 Thor Hurricane motorhome. Running poorly. We replaced the in tank fuel pump. All plugs and injectors. Running better, but still getting a code for a spout plug and speed sensor plug. Still not running right. Any suggestions? We can’t find a spout plug after searching for several hours.
I am moving you to 460 land. Even though the F53 should fit into the Large Truck forum, the 460 is an "unknown" in that forum as it was never offered in any medium or heavy truck.
we do not a service manual, but would like to acquire one. Any suggestions?
Ford puts the spout plug located near the ICM. On the F53s they are hard to get to and you might need to remove some stuff to remove/replace the spout.
When you say speed sensor code and spout code?
The codes are?
You need the 4 digit code and then start with the pinpoint tests for that code
You be guessing without that
