Slip yoke problem
Old Jul 15, 2022 | 12:31 AM
Ehigginbotham80's Avatar
Ehigginbotham80
3rd Gear
Slip yoke problem
Hey guys, I’ve recently done a 4x2 to 4x4 swap on my 94. The transmission and transfer case are from a 92 f250. My slip yoke on my 94 is too small and leaks transmission fluid when I used it to drive. Anyone have a link or know where to find a 4x4 slip yoke for a 92 4x4?
Old Jul 15, 2022 | 09:06 AM
tecgod13's Avatar
tecgod13
Jeffs Bronco Graveyard would probably have slipyokes, I think they did when I was searching for a solution for the other end when I was swapping in a superduty driveline to my '93.
How much is too small? did you replace the seal on the transfer case? There is also a bushing in the end of the transfer case, when the bushing wears, the slipyoke can wiggle and I believe that can also cause leaks, even with a new seal.
Old Jul 16, 2022 | 12:37 AM
Ehigginbotham80
3rd Gear
I called a local auto parts store and they told me there’s two different sizes of yokes, a 1 1/16” and a 1 3/16” yoke. My guess is that I have the smaller of the two.
I will try Jeff’s bronco grevyard, thank you for pointing me in some direction.
Blue_Betty
15
Dec 23, 2021 05:46 PM
brandonf150
Feb 25, 2017 02:07 AM
lyndalynda
Mar 4, 2016 05:27 PM
twkersh
Mar 6, 2001 11:06 PM
