hyper shifting
Old Feb 29, 2016 | 09:45 PM
lyndalynda's Avatar
lyndalynda
hyper shifting
what is the gear and shaft called the one on the outside of the back of the transmission on a 1991 ford f150 can anyone help me
Old Mar 1, 2016 | 06:45 AM
MtTheJeffro's Avatar
MtTheJeffro
If it's part of the transmission, it's the tail-shaft.
If it's the part that slides into the back of the transmission, it's called a slip yoke. After the slip yoke are the U-joints which hold the driveshaft to the slip yoke.
Old Mar 1, 2016 | 12:20 PM
Phy's Avatar
Phy
Are you perhaps talking about the transfer case? (if 4x4...)
Old Mar 4, 2016 | 02:38 PM
lyndalynda's Avatar
lyndalynda
its not a 4x4 its a 1991 f150 xl larret
would the tail-shaft have anything to do with the shifting of the truck
and do you know what i mean by hyper shifting
its driving me crazy
Old Mar 4, 2016 | 02:52 PM
MtTheJeffro
Changes in shifting pattern wouldn't be due to the tail shaft. And no, I have no idea what you mean by hyper shifting. Sounds like you need someone with a little more experience to have a look. You probably don't want to open up a transmission unless you really know what you're doing
Old Mar 4, 2016 | 04:33 PM
lyndalynda's Avatar
lyndalynda
what i mean about hyper shifting is it shifts through all the gears before im even out of 2nd and sometimes it shifts real hard into 2nd or 3rd
Old Mar 4, 2016 | 04:41 PM
lyndalynda's Avatar
lyndalynda
does my 1991 f150 xl have a place to plug in to get codes from if it does where is it located at
Old Mar 4, 2016 | 05:09 PM
MtTheJeffro
Does it have a check engine light? It doesn't have ODBII. Maybe ODBI. Off top of my head, I'd be looking at fluid level in the trans. I don't think you have a vehicle speed sensor but I'm not up to speed on your model specifically. Sounds like trans issues though
Old Mar 4, 2016 | 05:22 PM
ifrythings's Avatar
ifrythings
They call that shift stacking or stacked shifts when it goes 1-2-3 right after each other and your in 3rd at 20m/h (for example) and the thing is gutless then. Need to know more about your truck like what tranny you have to help further
Old Mar 4, 2016 | 05:27 PM
bashby's Avatar
bashby
There is a trans code on the drivers door jamb sticker that will tell you what trans you have. Some are electronic and you can get codes to help you diagnose.
78 f150 400
Feb 22, 2017 10:56 PM
farmer460
Aug 22, 2014 02:08 PM
BigBlue92
Nov 17, 2011 08:31 PM
cyclospot
Oct 13, 2007 01:44 PM
rockcrawl
Apr 26, 2001 10:21 AM
