Upper Intake Manifold Stuck
Old Jul 15, 2022 | 01:46 PM
AuroraGirl's Avatar
AuroraGirl
if still have issue, harbor freight has those little air pump bladders for moving things. if you can position something to like the frame and use that to slowly and carefully put pressure you could tap around the perimeter
Old Jul 15, 2022 | 02:36 PM
GoinBoarding's Avatar
GoinBoarding
Use of a paper gasket is all that's needed here.
Application of RTV to seal up the China walls on a lower manifold installation is entirely different.
Old Jul 15, 2022 | 06:32 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by jackhunter
I've never had any issues using it over the years, most 4 bbl intakes call for it on the China walls anyways.
Agree. Sealing the lower intake where oil is present is completely different than sealing the upper and lower manifolds where there is only air and some oil mist from the pcv system.
111989F250
Jun 19, 2009 01:12 PM
Green Streak
Jan 9, 2006 09:23 AM
jfsledge
Feb 12, 2004 01:02 PM
locknut550
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 14, 2004 09:50 AM
