Suggestions to see loading dock.
Old Jul 14, 2022 | 01:14 PM
Supra's Avatar
Supra
Last 20 years I could see loading dock when backing with tailgate down in my 96 and 05 Super Duty. My tailgate gets worked hard moving 550 lbs drums causing wear on gate hinges. So I'm needing to avoid the addional stress of bumping a 8500lb truck against those pins. I have had to R&R many sets.
My new 22, I can't see tailgate in my rear view mirror because the rear window is too high. Even though I have the bigger dash screen with the Lariat Ultimate Package the depth perception is poor using the bed camera above rear window. Tail gate camera looks wrong way when down and I cant seem to find the trick in judging when tail gate is up. Really frustrated on this. What am I missing here? Anyone have some tricks to try? I appreciate your help.
Old Jul 14, 2022 | 01:27 PM
The Peddler's Avatar
The Peddler
What about placing this on the tailgate when you lower it?
https://smile.amazon.com/TruePower-2...s%2C454&sr=8-5
Old Jul 14, 2022 | 02:53 PM
cficare's Avatar
cficare
Tailgate is aluminum, so where does the magnet go?
Old Jul 14, 2022 | 03:24 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You can stick it to any flat piece of metal and set that on the tailgate (assuming he's talking about just setting it vertical on top of the tailgate when lowered)
Aftermarket stand-alone backup cameras are pretty cheap these days. Maybe buy one and mount it somewhere near the license plate (or a license plate mounted camera) facing up toward your lowered tailgate.
Old Jul 15, 2022 | 06:37 AM
Pugga's Avatar
Pugga
Back into the dock with the tailgate up, determine your stopping point using the lines on the backup camera, then go drop the tailgate. Once you figure out where you need to stop with the tailgate up, it's easy to repeat. I don't have to back into loading docks often, but that's how I do it.
Old Jul 15, 2022 | 08:06 AM
RidgwaySD's Avatar
RidgwaySD
Seems like you are going to have to get a little creative to solve this. You have two cameras and a 12 inch screen which for most would seem to be massive overkill compared to the "old days" of using mirrors. My suggestion is a little flag spring loaded at the base that sticks up when the tailgate is down and has a short leg that sticks out as a feeler when you get within a couple inches of the dock and bumps the flag. Done right, with the gate up the flag disappears below the bed line with just 3-4 inches of the wire leg sticking up.
Old Jul 15, 2022 | 08:56 AM
redford's Avatar
redford
FTE Leadership Emeritus
Carry a monback with you?
That is a guy who gets behind the truck and says, "Monback........monback........monback.........WHO A."
Old Jul 15, 2022 | 11:22 AM
2020STX250's Avatar
2020STX250
If its something you do quite often, amazon and other sites have standalone camera and screen systems. You could use something like the builtright dash mount system to mount the monitor and then mount the camera somewhere in the bed off to the side with a good view of the down tailgate.
Old Jul 15, 2022 | 11:52 AM
1olddogtwo's Avatar
1olddogtwo
After 20 years, you think it's 2nd nature to do it.
ATV flag?
Old Jul 16, 2022 | 04:31 AM
KU4OJ's Avatar
KU4OJ
Get a 2x2 piece of wood and make a "gauge".... (or bigger, depending on your receiver)
Get the truck exactly where you want it with respect to the loading dock.
Cut the wood a bit longer and slide it into the receiver hitch and set it so it just touches the dock. Mark the location where the wood just enters the receiver.
Paint the end of the stick red (or other bright color) that's inside the receiver. Paint the rest of it black, or not at all
When backing up, put the "gauge" into the receiver with an inch or two of red showing.
Back up, tailgate up, using the back up camera. When the dock pushes the gauge far enough into the receiver so the red just disappears, then the truck is again at the perfect distance to lower the gate. And you did it without damaging anything and all in one shot.
Old Jul 16, 2022 | 05:00 AM
zoomeroo's Avatar
zoomeroo
Ser tail gate
What a great KISS method to address this.
as simple as a board in the hitch.
Great thinking.
I also like the aluminum magnet to hold a camera lol.
Old Jul 16, 2022 | 05:19 AM
KU4OJ's Avatar
KU4OJ
Dock Gauge V.2 has a hinge in the middle. Folding up the stick allows you to remove it without having to pull the truck forward, so you don't drive off with it still in there.
Old Jul 16, 2022 | 08:24 AM
Joe T's Avatar
Joe T
See about getting a 1080p camera for the cargo camera. I have read but not verified you can replace these cameras with better ones.
I would like to know if you post back that would be great.
Old Jul 16, 2022 | 10:16 AM
The Peddler
Ha! My bad, I totally forgot the gate was aluminum.
Old Jul 24, 2022 | 03:37 PM
602Alan's Avatar
602Alan
It's been some time since Ive heard of the monback, I was sure that they were an extinct species. I will have to run a Google search to find such a creature.
TicoTube
1978 - 1996 Big Bronco
19
May 3, 2013 03:03 PM
ford1977owner
Dec 30, 2011 04:48 PM
Robg
Sep 16, 2002 02:47 AM
icelander
Apr 17, 2002 01:42 AM
sharlo
Dec 26, 2000 07:31 AM
