Starting help
Old Jul 11, 2022 | 06:53 PM
JohnMack's Avatar
JohnMack
5th Gear
Starting help
Hi I have an 89 7.3l idi its start hard when its hot and not at all other times. I've tried the water truck and it did nothing but I did run a jumper wire from the battery to the cold advance prong on the injection pump and it started right off. Can anyone explain this to me? The truck was originally an automatic but was converted to a standard at some point.
Old Jul 12, 2022 | 10:46 AM
Olds64's Avatar
Olds64
Next time it doesn't start when it's hot take the fuel filter off and see if it's full of fuel. If it's only 1/2 full then you have air intrusion.
Old Jul 12, 2022 | 03:44 PM
JohnMack's Avatar
JohnMack
5th Gear
I forgot to mention I have an electric fuel pump I installed .
Old Jul 13, 2022 | 07:15 AM
Olds64's Avatar
Olds64
Then it's definitely a good idea to check for air intrusion. You can also add clear acrylic hose up by the fuel filter and look for bubbles in the fuel.
Old Jul 30, 2022 | 12:35 PM
JohnMack's Avatar
JohnMack
5th Gear
Well I finally got the chance to bleed the whole system out and now it starts when it's warmed up. Thank you
Petcodogtrainer
Apr 16, 2020 12:09 PM
jrod76
13
Oct 22, 2013 11:44 PM
Coolarctic
Jun 15, 2009 09:31 PM
mwb
Aug 22, 2006 07:33 PM
badam
Jun 16, 2006 07:36 PM
