6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Stops running while driving
Old Jul 11, 2022 | 08:32 AM
Glassman07's Avatar
Glassman07
4th Gear
Truck will be running good then it will suddenly stop running, started happening after fuel filter replacements and bled the fuel system
Old Jul 11, 2022 | 08:44 PM
DieselDenny's Avatar
DieselDenny
I recommend you pull the upper cap. Inspect surgically the cap for a crack or defective o ring..
If the bowl is full, I would think the rail filter is good. (lower). Trace leaks should be noticeable when parked.
Make sure your using a few drops of Diesel to lube the o-ring before reinstalling. They crank down hard so be careful to fully seat it.
Did you KOEO for 20 seconds 5-6 times after the filter changes?
Denny
Old Jul 12, 2022 | 09:48 AM
Glassman07's Avatar
Glassman07
4th Gear
I have already replaced those two items and didn't help and yes I did do the KOEO
Old Jul 12, 2022 | 02:15 PM
DieselDenny
What's your fuel level and did you replace filters/cap with motorcraft or aftermarket?
Denny
Old Jul 15, 2022 | 09:31 AM
Glassman07's Avatar
Glassman07
4th Gear
motorcraft parts
Old Jul 15, 2022 | 10:57 AM
73fan's Avatar
73fan
Put a gauge in and monitor low pressure fuel when it dies.
Old Jul 16, 2022 | 08:45 AM
Fefanatic's Avatar
Fefanatic
Start it and crack the upper filter cap until fuel runs out. I've had to do that on my cargo truck after fuel system service. It just doesn't bleed very well without human intervention. Also, make sure the filter cap on the lift pump at the frame is tight and not sucking air.
Old Jul 17, 2022 | 07:48 PM
DieselDenny
Again, did you verify fuel level?
shenders99
38
Sep 6, 2023 06:19 AM
WyomingHeeler
Oct 5, 2010 01:37 AM
bill1187
46
Dec 31, 2008 12:54 PM
drewk
Nov 18, 2006 08:42 PM
mds01
1978 - 1996 Big Bronco
Nov 25, 2004 08:23 AM
