Cam shaft position sensor tip
Old Jul 11, 2022 | 08:00 AM
Craig Maffet's Avatar
Craig Maffet
If you are having a stall. Getting code p2614 and goto replace your cmp - I’ve seen lot of vids on the change but only one post on the issue.
the bolt on flange sits on a flat part of the block. A small bit of rust can form behind the flange and bump the cmp out a hair and throw you off causing stalls. This **** was driving me crazy bc I could not
get the cmp to go flush.
after much frustration, I got under the truck and angled a light got in just the perfect position to see the entire mounting area and I finally saw it - it was a good size blog if rust 1/16”ish formed behind the flange. Flaked it off w a screwdriver and bang. Truck idles perfect now.
Old Jul 11, 2022 | 05:35 PM
BLADE35's Avatar
BLADE35
Good deal thanks for the update
Rodney Cook
2009 - 2014 F150
Nov 4, 2016 07:16 AM
ithaca1230
Aug 17, 2015 08:04 AM
Ythomas
1983 - 2012 Ranger & B-Series
Jun 16, 2013 02:34 PM
