EPS MALFUNCTION
Old Jun 19, 2022 | 06:58 PM
ZekeD's Avatar
ZekeD
EPS MALFUNCTION
Well, Jack will be pleased, as I have bought FORScan and an OBDLink MX. still have intermittent Glow Plug #5 issues, but now I have a B1318 error which translates to “blown EPS Fuse” or EPS CM malfunction.
For the life of me I cannot find an EPS Fuse location. I have searched this and other forums, and even (Wait for it) read the manuals that I have…. No Joy.
Any help would be appreciated
Zeke
Old Jun 19, 2022 | 07:00 PM
ZekeD's Avatar
ZekeD
Sorry, 4.5 6.0 drw cc F350
Old Jun 19, 2022 | 07:13 PM
bismic's Avatar
bismic
B1318 Battery Voltage Low
Old Jun 19, 2022 | 09:58 PM
ZekeD's Avatar
ZekeD
Right……..But
It isn’t. 12.6 at rest. 13.8 after start-up. Both are less than 4 months old. Starts on first click.
still………
thanks, Zeke
Old Jun 19, 2022 | 10:03 PM
ZekeD's Avatar
ZekeD
Forgot….
Banks Tuner, upgraded cables between batteries, neg to frame etc etc. per this forum’s recommendation.
Old Jun 20, 2022 | 12:06 AM
BLADE35's Avatar
BLADE35
I’m not sure the exact condition the low voltage dtc triggers at but it may drop out of spec during crank something to watch anyway
is your battery light illuminated on dash
Old Jun 20, 2022 | 03:58 AM
Yahiko's Avatar
Yahiko
I think that a health check of the charging system is in order and then a load test of the batteries.
Old Jun 20, 2022 | 07:09 AM
bismic's Avatar
bismic
still………
thanks, Zeke
Also, I'd recommend seeing what the PCM thinks the vehicle voltage is.
Old Jun 20, 2022 | 12:11 PM
ZekeD's Avatar
ZekeD
Work cut out for me
Thanks guys. I will post back when I get any results
Zeke
Old Jun 20, 2022 | 10:12 PM
ZekeD's Avatar
ZekeD
Going to be awhile
Yep. I broke my hand Sunday while rodeo-ing. I guess you aren’t supposed to do that at 75……. Wife says “no more bareback riding for you”. I’ll get to the Ford as quick as I can.
Zeke
Old Jun 21, 2022 | 03:05 AM
Yahiko's Avatar
Yahiko
Stick a saddle on that pinto and maybe you can stay in the driver's seat.
Sorry about that bad one.
I have an Arabian I was riding take me on a trail making run. Not sure if what spooked him with a real
think of something he happened to think was there. He could be a real spook every now and then.
Take care of the hand. Hope it gets better quickly.
Old Jun 22, 2022 | 09:52 AM
ZekeD's Avatar
ZekeD
It will heal
I like Arabians….feisty lil guys. My main horse now is an Appaloosa. Bought him off of the Indian res. He is a wild horse, but he loves me❤️ Big motor. Yeah I whacked my left hand leaving the chute, second time now. It was 8 years ago so I guess I forgot 🤪. I’ll get after the Ford if I can find some help.
Old Jun 22, 2022 | 11:46 AM
Yahiko's Avatar
Yahiko
Too bad your not a little more up this way.
One thing to look for is rodent chewing or battery cables that need cleaned/replaced.
I do miss that wild boy. He was fun other then when if spooked. I spent months training him as he was green broke
and then turned out with no one riding him for a very long time. After one bad day when he took the bit and dumped
me on the arena gate I only let him walk or trot for weeks. Then one day I was pushing him to as fast as he could go
at a trot and he broker one into the smoothest canter. His reward after that was to let him do more. A friend I used to
ride with took both her's and my hourse out into the big field and let them run. At that point he was so much easier
to control. I found that it always helped to have a second horse with us sort of support and a buddy to stay with.
Old Jul 1, 2022 | 05:58 PM
ZekeD's Avatar
ZekeD
Tough it out
Ok, rodeo fans……I got tired of waiting and jumped in and replaced the odd glow plugs and harness. Starts and runs great. It dropped the #5 glow plug warning but I am still getting “low battery (b1318)” although the battery reads 12.2 at the cigar port. I will remove and refresh the wiring as soon as I get my hand out of this ice water.😳
thanks
ZD
Old Jul 1, 2022 | 06:07 PM
bismic's Avatar
bismic
Usually B1318 is when the Instrument Cluster thinks the voltage is low.
12.2 volts is low btw. That is about 50% State of Charge ............ But then it is best to measure at each battery AND to check on what the PCM thinks it is (as posted above).
https://www.mmbalmainauto.com.au/PDF..._batteries.pdf
