shocks
From opinions on here, several years back I bought the KYB MonoMax's and I can't stand the ride.
They turned my 2003 V10 4WD into a rattle box.I hate driving the truck and I'm tired of apologizing to passengers, so I don't drive it too often. I've only put a couple thousand miles on them hoping they would loosen up, but nope, still hate them.
I want the smooth factory ride, I don't off-road. Stock height and wheel size.
Any other thoughts?
1. what tire pressure are you running front and rear ?
2. what shocks did you have on before?
3. Can you post a pic of your front springs and the shock ?
while I certainly appreciate everyone has their own ride preference a KYB monomax should not transform a Ex into a rattle trap.
a ride that is to stiff for your liking ? Sure but not a rattle trap. Me thinks there is something else going on.
i have my hunches but a pic would help.
edit… all 4x4 excursion trim models have identical suspension, the trim levels are just that… the frilly bits not the suspension or powertrain
for the stock size tires the pressures listed on your door jamb are the correct pressure for a fully loaded Excursion,
the front is 50 and the rear is 55 psi.
Ride quality is highly tire pressure sensitive but since payload is also pressure sensitive i would just run them at the maximum on your door jamb.
at 80 psi the 265/75/16 can support 6800 lbs.
at the factory rated rear 55 they support 5200 lbs
your rear axle is only rated to support 5200 lbs.
in other words the extra payload you are getting by such a high pressure is wasted since its far past the excursions payload and your ride quality is suffering because of it.
but that isn’t what i think may be your biggest issue. Pics should tell that story.
I was thinking about the tires pressures and think maybe I should start by adjusting it down.
I have always ran high pressure, but failed to consider the stock shocks are not the same as the KYB's, and may require less pressure for the smooth ride I am looking for.
The way it works is as follows:
1) find a stretch of highway where you are able to bring your tire temps up to their max.
2) pull over at safe place to check your temps.
3) quickly take tire temp readings on each tire by sticking your probe (or point your laser) onto three points of the tire tread (the outside/center/inside).
4) record your three (3) readings for each tire.
Ideally, you want the readings to be the same across each tire. The readings may vary between tires, but on each individual tire, the readings should be the same.
If the outside and inside temp readings are higher than the center, your pressure is too low.
If the outside and inside temp readings are lower than the center, your pressure is too high.
If you have a different reading across the tread at each point, you need an alignment.
In auto racing, this is how they get the most tire on the pavement to maximize grip. For our purposes, it not only provides the most grip, but it also provides the longest tire wear.
Hope this helps.
The bump bolts to frame, i can just make out the remains of the mounting plate, circled.
there are 2 varieties ford used on the Ex.
a small and large2C7Z-3020-AA Small
YC3Z-3020-AA Larger
If it were mine, i would also remove each front shock and check to make sure they are still functioning at the same time you are replacing both bumps.
I have Bilsteins on every vehicle I own. 4600s are the same length as stock. There might be a softer shock out there that simulates your OEM feel, but remember, your shocks are old and worn out.
