EGT Temps
Old Jul 8, 2022 | 01:07 AM
credgmon's Avatar
credgmon
EGT Temps
I have block off plates with stock probe in the top front block off plate. On auto agent I only have one EGT temp that actually reads(only under acceleration). My temps don’t get over 300ish so I know something must be wrong. Wondering why it’s not reading correctly up to 1000 + ?? Any info ???
Old Jul 8, 2022 | 09:09 AM
senix's Avatar
senix
who did your tune work. Need to speak with them about your issues with the tuner.
Old Jul 8, 2022 | 10:06 AM
credgmon's Avatar
credgmon
its just an EZlynk and my stock EGT probe. So my question is, do I need an aftermarket probe or something.
Old Jul 8, 2022 | 12:40 PM
senix's Avatar
senix
what tune are you using?
Old Jul 8, 2022 | 01:05 PM
credgmon's Avatar
credgmon
No em. ECM. LBF. QR. SOTF 0-200HP. V2.4.3
I’m reading it through the Auto Agent app plugged into a splitter for that and my steps. I have full SPE piping kit and block off plates with the stock EGT probe. I’m reading EGT sensor 11 because EGT 12 & 13 just show 2300 and are maxed out like they aren’t giving a reading. EGT 11 is reading in the 400s
Old Jul 9, 2022 | 01:40 AM
Blazn's Avatar
Blazn
You have to pull an egt probe from your dpf to plug into the block off plate. It should be the first probe on the dpf closest to the downpipe. Attached below is a thread with info sourced from PPEI. There's also a video for refence. The 43 minute mark is where he addresses your question. Hope this helps.
https://www.ford-trucks.com/forums/1...questions.html
Kemicalburns
Dec 14, 2017 10:50 AM
brit_wheels_fan
Sep 12, 2015 09:24 PM
05 f250 6 inch lift
Oct 26, 2010 07:51 AM
orionife
Dec 27, 2007 04:37 PM
dhelm72
Sep 4, 2005 09:15 PM
