Thank You AuroraGirl,,, I certainly appreciate Your information,,, Cheers Graeme...
Originally Posted by AuroraGirl
Nevermind, I found 2 websites that both allowed it to show results. NHTSA helped here, even tho it was made in canada and probably never has come here. Its likely because canada signed on to a lot of the NHTSA / EPA regulatory things as far as vehicles go
the big problem with this is that ford did not make a F-450 until 1999.
that truck is a F-Superduty.
it says so rite on the fender emblem.
The fender emblem on my F-[whatever it is] says "Bronco", so take that for whatever it's worth.
Ford refers to it both as an "F47" and an "F-Super" depending on context. The GM version of this truck is just as confusingly named- "3500 HD", although, like the F-super, it has virtually no chassis parts in common with its 1-ton counterpart. I have to think that at the time, both of these competing products were put out by half-assed teams that weren't really sure if they were selling a medium truck or a light truck and the naming just ended up being a mess.
the F47 in the VIN denotes that it is a F-Superduty. Ford never called it a 450. that designation only started by people mistakenly calling them 450's after the 450 was introduced in 99.
as far as 1989 went, I do not believe GM produced a direct competition of a grade 4 chassis but they did for sure a grade 3 in their legacy R/V chassis models, not sure about the GMT 400s C/Ks tho for that matter
