Fuel lines
Old Jul 6, 2022 | 04:55 PM
bk117wrench's Avatar
bk117wrench
Fuel lines
I need the two rubber fuel lines that come off the front of the fuel filter. The ones with the flare fittings. Had a blow out on I85 near Exit 6 in Georgis today. Are these available or made at a hyd shop?
Old Jul 6, 2022 | 05:12 PM
bk117wrench
Found it, Raffaffs..
Old Jul 6, 2022 | 05:18 PM
TucAZ's Avatar
TucAZ
I just installed an electric fuel pump kit and replaced those, the kit uses push-lok fittings into rubber. I also had a blow out on the old ones, last month. Lost 5 gallons or so in the Safeway parking lot. The parts you are looking for are the fuel return lines. If you are stuck on the road, maybe try a hose barb coupler and clamps, fuel pressure is around 60psi so get the "fuel injection" clamps and fuel line capable of at that psi. If its the drivers side line, you must remove the AC compressor, then the steering pump bracket. I just left one bolt in a few turns and turned it out of the way. Then you can access the the drivers side return line. It sucks.
Old Jul 7, 2022 | 06:00 AM
bk117wrench
IKR? I just filled up and noticed my fuel quantity indicator at 3/4 full after 4 minutes. Pulled over and saw fuel everywhere. A really nice guy at the gas station in Lagrange GA drove me to Orielly's. I got the hose mender and two clamps. The line was in such bad shape the mender almost did not work. 200 miles later I got home. I was pretty nervous driving thru Atlanta.
Old Jul 7, 2022 | 11:30 AM
Hit Man X's Avatar
Hit Man X
Happened to me five years ago right after I purchased the 96. Riffraff now makes better lines, picked up a set recently.
Those and swapping the OBOD should be immediate with a fresh purchase.
Old Jul 16, 2022 | 12:42 AM
B_bimmer's Avatar
B_bimmer
4wd Low
Can someone link me to the lines being discussed? Or post a picture pointing them out, I've never had a problem on any of the trucks I run and would like to take a closer look if some preventative maintenance would be wise.
Old Jul 16, 2022 | 09:09 AM
ojh's Avatar
ojh
Well, I see something I'd better look into ASAP, who is this 'riffraff' you mention?
Thanks, Oj
Old Jul 16, 2022 | 10:03 AM
helifixer's Avatar
helifixer
https://www.riffraffdiesel.com/drive...el-line-94-97/
Old Jul 16, 2022 | 10:13 AM
Hit Man X's Avatar
Hit Man X
Just ordered a set for my 96. The ones from it go to the 97.
rudystrick
Aug 13, 2020 01:14 PM
D Walker
Feb 20, 2018 06:09 PM
sudsmcduff
Apr 5, 2016 02:36 AM
CoachRobb
Jul 9, 2007 08:11 PM
firemanp
Jan 12, 2006 07:28 PM
