Low oil pressure
Old Jul 5, 2022 | 11:35 AM
paul.table's Avatar
paul.table
Low oil pressure
I have a flathead V8 and run an electric fuel pump . The existing pump has been removed with the operating rod cut short where it enters the housing near the camshaft so it no longer runs on the cam, a cover plate and gasket fitted in where the pump was located. The operating rod housing is worn and the rod wobbles about in the hole. Will this cause low oil pressure? I'd be interested in your thoughts, thank you.
Old Jul 6, 2022 | 05:46 AM
bernette's Avatar
bernette
on my c69 there is no oil flow there . worried me at first . i got good oil pressure and rod is removed completely. i had made a video of the hole with engine running .
Old Jul 6, 2022 | 06:04 AM
bernette's Avatar
bernette
page 23 on my built tread post 333 ,if you want to see the video .
Old Jul 6, 2022 | 02:11 PM
paul.table's Avatar
paul.table
I would very much like to see the video you suggest , however I cannot find the page or the post. Could you please supply a link by chance?Many thanks
Old Jul 7, 2022 | 05:39 AM
bernette's Avatar
bernette
https://www.ford-trucks.com/forums/1...2-2ton-23.html
Old Jul 7, 2022 | 05:42 AM
bernette's Avatar
bernette
third one down ,should work .
Old Jul 8, 2022 | 10:51 AM
paul.table's Avatar
paul.table
Many thanks to you, I see no oil flow so I guess all is OK. Fantastic build you have been through, I'll have a good read through.
johnfl
Jan 24, 2017 05:05 PM
kweiss
Mar 28, 2012 06:16 AM
skeleton33
Flathead V8 & Flathead 6
Aug 10, 2004 05:24 PM
lastchance
Jun 7, 2001 06:35 PM
