Strange speaker wires
Old Jul 4, 2022 | 06:07 PM
indy358's Avatar
indy358
I just purchased a 96 F150 XLT ext cab. It has a aftermarket radio. Only the driver rear speaker was working so I pulled the head unit to investigate. The power plug was intact but the speaker plug had been cut off and the speakers wired direct to the head unit. As I was trying to sort out the mess I noticed the wires in this 96 were smaller and different colors than in my previous 95 and 93 models. I looked up several diagrams of the factory wiring and they were all the same, non of the speaker wire colors matched. I'm 99% certain the wires are factory as they are loomed to the power wires with cloth tape under the dash.
Has anyone else come across this? I managed to isolate each speaker so I know what wires go where but I'm going to have to pull the speakers to confirm +/-. I'm hoping someone has dealt with this and can save me pulling the door panels.
Old Jul 4, 2022 | 06:24 PM
Conanski's Avatar
Conanski
Wiring colors cannot be relied upon from once year to the next and that is nothing unusual for these trucks in my experience.
Old Jul 4, 2022 | 09:02 PM
AuroraGirl's Avatar
AuroraGirl
Helpful?
Old Jul 4, 2022 | 09:22 PM
wwhite's Avatar
wwhite
Maybe you have premium sound system, which has an additional external amplifier.
That could explain the difference in wiring you are noticing.
Old Jul 4, 2022 | 10:21 PM
indy358's Avatar
indy358
You are correct but considering all of the schematics I found online seem to match up to what I remember from the other two trucks it was strange that these were different. Also the wires in the 96 are of a smaller gauge which I also found strange.
Old Jul 5, 2022 | 12:16 AM
AuroraGirl's Avatar
AuroraGirl
The rest I throw in because it dpeends on what you have on yoru vehicle. So hopefully it helps
heres what @wwhite was saying maybe you have
Old Jul 5, 2022 | 02:50 PM
Scndsin's Avatar
Scndsin
I ran across tip, maybe from Crutchfield for testing speaker wiring polarity with 9 vlt battery.
You brush the leads at the head unit end across the battery terminals & you will only get scratching sounds with correct polarity.
Old Jul 5, 2022 | 03:39 PM
wwhite's Avatar
wwhite
Do not hold speaker wires on battery for extended periods of time.
Also, when connecting to the battery, watch the direction of the speaker cone:
If the speaker moves outward, then the speaker wire connected to the positive (+) terminal of the battery is the positive (+) wire.
If the speaker moves inward, then the speaker wire connected to the negative (-) terminal of the battery is the positive (+) wire.
Hockeymandan
Sep 27, 2013 08:12 PM
memobug
Sep 15, 2013 12:12 AM
killaguerilla
Mar 3, 2010 09:24 PM
mattd860
Nov 9, 2005 04:37 PM
fordtrucklover94
Dec 26, 2004 06:54 AM
