Sponsored by: Real Truck
Question on transmission
Old Jul 2, 2022 | 07:44 PM
Ajbaker's Avatar
Ajbaker
2nd Gear
Spoiler
Old Jul 2, 2022 | 07:54 PM
Ajbaker's Avatar
Ajbaker
2nd Gear
These are my code
Old Jul 2, 2022 | 08:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
P0781 means there is a problem with the 1-2 shift. P0782 means there is a problem with the 2-3 shift. Yes, the trans can make the engine hit the rev limiter at 50 MPH.
Old Jul 2, 2022 | 10:24 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Welcome aboard!
Old Jul 3, 2022 | 10:51 PM
donjamer's Avatar
donjamer
Moved to Appropriate forum
Old Jul 3, 2022 | 11:37 PM
m-chan68's Avatar
m-chan68
Originally Posted by Ajbaker
These are my code
To add to this, P1316 is an internal IDM failure code if memory serves me correctly. While P0470 and P0478 are EBP sensor related type codes and P1211 is something to do with injector control pressure (ICP) being out of range. It is obvious you have a 7.3L diesel truck. I suspect something is amiss with the engine driveability which may have something to do with your transmission symptoms as well.
Old Jul 4, 2022 | 10:46 AM
bwguardian's Avatar
bwguardian
I've noticed that when there's issues with the 7.3L power plant and it's down on power, the transmission will throw codes if driven any decent distance. So get the issues fixed relative to the engine and go from there...
Old Jul 4, 2022 | 10:51 AM
Mark Kovalsky
That's good advice. Any engine problem can cause trans problems. Often, fixing the engine problems also fixes the transmission problems.
