Sponsored by: Real Truck
Transmission Compatibility
Old Jul 2, 2022 | 07:22 AM
cckemm's Avatar
cckemm
4wd Low
At work we have 2 - 2005 F550 Super Duty Service trucks. Truck #1 V-10 gas, motor blown. Truck #2 6.0 Diesel, transmission dead. From my research on the forum is does not look like I can take working transmission from truck #1 and put it into truck #2, is this correct?
I can check the door stickers when I am up there next but it appears that they came with different transmissions and will not just bolt up or work with the electronics.
Thanks for any insight.
Chris
Old Jul 2, 2022 | 10:34 AM
m-chan68's Avatar
m-chan68
Nope. Although both trucks are equipped with the 5R110W transmissions behind different engines. There are internal mechanical differences as well, not to mention the transmission from the V10 gasser will not bolt up to the 6.0L diesel rear cover.
Old Jul 2, 2022 | 11:36 AM
acdii's Avatar
acdii
The hard parts wont hold up to the torque of the diesel. You would be better off having the transmission rebuilt to a bullet proof spec. It will last the life of the diesel then. . There was a guy, don't know if he is still around, that would rebuild transmissions with his own hard parts that were superior to Fords. BDS, or BSD or Brad or something along those lines, and the price wasn't much more than a standard rebuild.
Old Jul 2, 2022 | 11:39 AM
cckemm's Avatar
cckemm
4wd Low
Thank you All, answers my question. Diesel truck is sitting at about 245 K, we will not be rebuilding a trans for in it. Just thought we could give it a bit more life until the rest was unserviceable.
Old Jul 2, 2022 | 12:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Wrong. See below.
Wrong. See below.
Other than the torque converter, the V10 trans will work just fine behind the 6.0L. If you were to install a 6.0L torque converter in the V10 transmission you would end up with a better transmission than the 6.0L had originally. Everyone else that posted above is just plain wrong.
There are only two differences between a V10 and a 6.0L transmission in 2005. One, the torque converters are different. The 6.0L has six studs and the V10 has four studs. The second difference is the intermediate one way clutch. They are both the same strength, but the one in the V10 has a lower allowable lash. The 6.0L one causes clunks on the 2-3 shift. It wasn't super noticeable on the diesel, but it was awful on the gas engine. So they spent the money for a better one way clutch to solve that issue. I was not successful when I tried to get that clutch in the diesel.
There was only one bellhousing pattern for all 5R110W transmissions. All engines that used the 5R110W used the modular engine bolt pattern, including the 6.0L and 6.4L diesels.
Old Jul 2, 2022 | 12:30 PM
OverheadCram's Avatar
OverheadCram
What Mark provided is good information.
I was unaware of the intermediate clutch difference between gas and diesel, but was aware of the torque converter when I swapped a 5R110W from a 2006 F250 5.4L into a 2003 F450 6.0L. All works fine and the 5R110W has over 15k miles now behind the 6.0L.
Old Jul 2, 2022 | 02:34 PM
cckemm's Avatar
cckemm
4wd Low
Thanks for all the reply's. I will double check the door stickers when I get up to that jobsite and make sure they both list the same transmission and leave the people higher on the totem pole decide if they want us to move forward with this.
The transmission that died was diagnosed with an internal pressure leak. It works for a few seconds after you start the truck then acts like it sucked air. I can usually put it in gear right after starting and move it a few feet. Only reason I came up with the sucking air thought is by engaging the pto and watching my hydraulic pressure on that system. The pto will come right up to pressure for a few seconds then the needle will bounce a few times then drop to zero.
Estimate to repair the transmission was comparable to installing a rebuild. That was already decided against as either repair cost more than the truck is worth. But if we can swap transmissions that puts us back into a workable solution.
Old Jul 2, 2022 | 02:37 PM
Mark Kovalsky
The 5.4L trans DOES have differences from the V10/diesel trans. Some of the clutches, and I don't remember which ones, have less clutch plates in the 5.4L version, making this trans weaker than its brothers.
Old Jul 2, 2022 | 03:02 PM
Sparky04SD's Avatar
Sparky04SD
Would this apply to the ZF6-750 as well?
Old Jul 2, 2022 | 03:14 PM
Mark Kovalsky
Of course. They didn't make a special engine for the manual transmission trucks.
Old Jul 2, 2022 | 03:58 PM
m-chan68's Avatar
m-chan68
Mark you are usually spot on with your information.... except this one time. Ford made two different rear engine covers for the 6.0/6.4 engines. One is for automatic transmission applications and the other for the ZF6 manual transmission. Why Ford did this is beyond me. What does this mean? If your ZF6 equipped 6.0/6.4 engine is blown and you want to go the route of replacing with a used engine, you will either need to source out one that came from a manual truck as well (very difficult due to the low take rate for the manual), swap rear engine covers (lots of extra work) to get the engine to bolt up. The ZF6 transmission cases that are 6.0/6.4 specific are a more circular shaped pattern than that of the 5.4/6.8 engines.
Sorry to the OP for the hijack.
Old Jul 2, 2022 | 04:24 PM
Mark Kovalsky
I stand corrected. I didn't know that.
I expect Ford did that because ZF wanted too much money to change the bellhousing on the transmission. That's my guess.
Old Jul 2, 2022 | 08:44 PM
OverheadCram
The appropriate way of viewing the situation is not what the truck is worth if it were to be sold, but instead what is it worth working? If a transmission rebuild is all that is needed to put a truck that im assuming has paid for itself already back to work and further its ROI, then that would be what I would do.
Old Jul 2, 2022 | 08:49 PM
OverheadCram
I had run across that information, but could never confirm. The transmission is holding up and I change fluid and screen every 5,000MI. Nothing looks or smells out of place.
Old Jan 20, 2026 | 02:20 PM
cvines1452's Avatar
cvines1452
2nd Gear
can I use a 6.0 transmission in my 06 ford f250 5.4 triton do I have to change anything
